Rule timer
Allras82
Rule timer
#1 Post by Allras82 » 12 Apr 2021, 20:15
How many timers is availabl in each of the 3 rules
And is the timer numbering global across all 3 rules?
Br
Ar
Re: Rule timer
#2 Post by TD-er » 12 Apr 2021, 21:13
Timers are global.
You can see the rules files as being one concatenated big rules file (except a block of "on ... endon" should be in the same file)
If my memory serves me well, there are 8 timers. At least there used to be, not 100% if I removed that limit.
dr.zorg82
Re: Rule timer
#3 Post by dr.zorg82 » 28 Apr 2023, 08:14
Good afternoon. how many timers can be put in the rules now? at the moment I am using 8 timers, how many more timers can I set up for the module esp32 to work properly?
Re: Rule timer
#4 Post by Ath » 28 Apr 2023, 08:47
The max number of timer at the moment is 256. Not sure what that will do with performance and memory use though, especially on ESP8266 :lol:
dr.zorg82
Re: Rule timer
#5 Post by dr.zorg82 » 28 Apr 2023, 12:46
thank you :)
Users browsing this forum: Anthropic Claude Bot [bot], YandexBot [bot] and 18 guests
