Thinkspeak does not receive all of the data
I have problems with Thinkspeak, the data is only partially arriving
Just updated to mega 20210802
ESP_Easy_mega_20210802_test_B_ESP32_4M316k.bin
I configured the Thinkspeak Controller as follows:
Task 1, 4, 60 controller no.3 should be transferred
However, only data from controller no. 1 and 4 are displayed.
Also with the command under Rules:
SendToHTTP, api.thingspeak.com, 80, / update? Api_key = xxxxxxxxxxxxx = [BH1750 # Lux]
it didn't work.
Does anyone have an idea why this might be?
Greetings Dondolo
it didn't work.
Greetings Dondolo
- task.JPG (135.79 KiB) Viewed 6265 times
- Unbenannt.JPG (65.41 KiB) Viewed 6265 times
Re: Thinkspeak does not receive all of the data
What Controllers are configured at slots 1 and 2?
Is this command correctly written?
SendToHTTP,api.thingspeak.com,80,/update?api_key=xxxxxxxxx&field3=[BH1750#Lux]
- controllers.JPG (59.56 KiB) Viewed 6261 times
You might want to take that key out of your post.
I don't speak ThingSpeak, so can't say how correct that is.
With, typed too fast. Yes, but how?You might want to take that key out of your post.
Your post has a pencil button in the right top, that's the Edit button
a little smarter again, thank you.
And an idea about the actual problem?
What interval is used to send data to the controller?
So the interval of the tasks.
You have the controller set to only send a message every 15 sec and the queue full action is set to "ignore new".
I think with the large interval needed by Thinkspeak, you may want to set it to "delete oldest".
Also try to make a list of values you try to send and at what interval.
It could be you're filling up the queue with messages from only 1 or 2 tasks and ignoring the rest because the queue is full.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 9 guests
