Binary of Dev Versions > R78 ?
njordan
#1 Post by njordan » 30 Mar 2016, 08:22
Are there somewhere DEV versions like R91 to download already as binary.....? or is there a simple way to convert into binary?
Thanks,
Norbert
Drum
Re: Binary of Dev Versions > R78 ?
#2 Post by Drum » 31 Mar 2016, 12:31
Links to Git hub and instructions for compiling in the Arduino ide are in the wiki
http://www.esp8266.nu/index.php/Main_Page
Although I believe you need version 2.1 in the board manager, searching in the forum helps ;) , or check the change log in Git and in the forum.
njordan
#3 Post by njordan » 01 Apr 2016, 10:31
thanks, i tried to compile directly before....but what do i have to put as the board in board manager? there is so many ESPs inside....I have a esp12e....also what settings is best/bringing succsss...there is MHz, SPI DIO.....is there any kind of guide for someone not so much into these details......thanks again
Drum
#4 Post by Drum » 08 Apr 2016, 14:19
See above post, the wiki has very detailed instructions. the Arduino ide has settings for ESP12E. Use the defaults.
You only need to connect it to a computer once, after that export to a .bin and use the upload function, it works really well. ;)
