Are there somewhere DEV versions like R91 to download already as binary.....? or is there a simple way to convert into binary?
Thanks,
Norbert
Binary of Dev Versions > R78 ?
Re: Binary of Dev Versions > R78 ?
Links to Git hub and instructions for compiling in the Arduino ide are in the wiki
http://www.esp8266.nu/index.php/Main_Page
Although I believe you need version 2.1 in the board manager, searching in the forum helps
, or check the change log in Git and in the forum.
thanks, i tried to compile directly before....but what do i have to put as the board in board manager? there is so many ESPs inside....I have a esp12e....also what settings is best/bringing succsss...there is MHz, SPI DIO.....is there any kind of guide for someone not so much into these details......thanks again
See above post, the wiki has very detailed instructions. the Arduino ide has settings for ESP12E. Use the defaults.
You only need to connect it to a computer once, after that export to a .bin and use the upload function, it works really well.
Users browsing this forum: Bing [Bot] and 11 guests
