External Time Source -DS3231 need help
Dondolo
#1 Post by Dondolo » 18 Dec 2021, 08:42
due to construction work we no longer have internet.
The idea is to make the time available with the IC2 DS3231.
I just have no idea how to set the system time with the DS3231.
Of course, you can do this via command:
datetime, 2021-12-17.21: 13: 00
Is there a plugin e.g. No. 157
Re: External Time Source -DS3231 need help
#2 Post by Ath » 18 Dec 2021, 09:47
That time source is available in the ESPEasy core, documentation is here: https://espeasy.readthedocs.io/en/lates ... l#advanced
It is intended to be used in an internet-limited situation, like yours.
#3 Post by TD-er » 18 Dec 2021, 10:37
Not just limited for use cases with limited or no internet, but also for logging + deep sleep setups.
I recently made a board for someone who needs to work as long as possible on a battery and WiFi reach is not guaranteed
So there is a GPS on board to get the time and turn off the GPS when a fix has been acquired. (thus also the time is set)
As soon as the time is set (either via the command mentioned or via NTP or GPS), it is stored in any present RTC chip.
At boot, the time is restored from the RTC chip.
The time source is also shown in the sysinfo page.
Dondolo
#4 Post by Dondolo » 18 Dec 2021, 10:59
I saw the documentation too, but it didn't really help me.
I had to change the battery in the DS3231 chip and the following time is displayed when booting.
How can I tell the DS3231 chip the new/correct time?
after Reboot.JPG (16.86 KiB) Viewed 21078 times
#5 Post by TD-er » 18 Dec 2021, 11:14
Just power cycle the board and if it does show a time which should match with the last seen time, then it is reading from the RTC chip and the chip is counting, powered from the coin cell.
Just set the time using NTP once, or use the datetime command
The command you gave was using a dot instead of a comma (and spaces)
See: https://espeasy.readthedocs.io/en/lates ... l-commands
Dondolo
#6 Post by Dondolo » 18 Dec 2021, 12:08
Hi Td-er,
that was a copy and past mistake.
Datetime,2021-12-18,11:26:00
But it doesn't even work correctly spelled. After booting, 1970-01-01 is displayed again. With or without NTP.
after Reboot1.JPG (16.86 KiB) Viewed 21074 times
I connected the chip to IC2 (D1 / D2),3V,GND. The chip has an additional pin header with SDA, SCl, 32K, SQW.
The following version is installed:
ESP_Easy_mega_20211005_normal_ESP8266_4M1M
#7 Post by Ath » 18 Dec 2021, 12:40
Datetime is an internal command, so you either set it from the Tools page or from a rule.
When setting it from the Tools page, does it show Ok as a result?
Dondolo
#8 Post by Dondolo » 18 Dec 2021, 12:51
Hi Td-er,
everything back it works, I idiot inserted the battery incorrectly; - ((sorry
Now I wanted to update the time on other ESPs via the http command.
Why does this command work, time and date are transferred.
SendToHTTP 192.1xxx,80,"/control?cmd=event,UhrzeitDatum=%systime%,%lcltime%"
This only transmits the date.
SendToHTTP 192.168xxxx,80,"/control?cmd=event,DatumUhrzeit=%lcltime%,%systime%"
#9 Post by TD-er » 18 Dec 2021, 13:50
I think you may need to wrap the arguments in quotes.
It seems like either one of them is seen as a formula and interpreted as such.
Does seem like a bug though, but I have no idea where.
Seems like the sendToHttp is perhaps parsing one step too often.
SendToHTTP 192.168xxxx,80,"/control?cmd='event,DatumUhrzeit=%lcltime%,%systime%'"
Wrapped the event command in different quotes (single quote)
Dondolo
#10 Post by Dondolo » 18 Dec 2021, 17:42
CODE: Select all
Unfortunately, wrapping doesn't work.
ESP that sends
SendToHTTP 192.xxx,80,"/control?cmd=event,Uhrzeit=%systime%"
SendToHTTP 192.xxx,80,"/control?cmd=event,Datum=%unixtime%"
SendToHTTP 192.xxx,80,"/control?cmd='event,DatumUhrzeit=%lcltime%,%systime%'"
ESp who receives
Is it possible to use the Unix time? The only thing I don't know is the conversion.
#11 Post by Ath » 18 Dec 2021, 19:14
The first quote in your SendToHTTP command seems to be a single quote, but the given example has a double quote there. That might change things.
#12 Post by Ath » 18 Dec 2021, 19:22
Hmm, looks like the SendToHTTP command does mess up the quotes in some way.
Dondolo wrote: 18 Dec 2021, 17:42 ESP that sends
You might want to use the date and time separate:
SendToHTTP 192.xxx,80,"/control?cmd=event,DatumUhrzeit=%sysyear_0%-%sysmonth_0%-%sysday_0%,%systime%"
[/quote]
#13 Post by TD-er » 18 Dec 2021, 20:28
If this does work, then it is the space in %lcltime% that messes things up here.
For example:
%lcltime% => "2021-12-18 20:25:29"
When sending a command, a space and a comma are both considered as a parameter separator.
However, as a separator of event values, only the comma is considered.
I think we also need a %sysdate%, or let the datetime command also accept a unixtime.
Dondolo
#14 Post by Dondolo » 19 Dec 2021, 03:20
CODE: Select all
Yes, it works, the date and time are transferred correctly.
Send ESP
Send ESP
ESP received
ESP received
SendToHTTP 192.xxx,80,"/control?cmd=event,Datum=%sysyear_0%-%sysmonth_0%-%sysday_0%"
If I then execute the datetime command with the% eventvalue%, the time is not written correctly.
on DatumUhrzeit do
if %sysyear_0% <= 1970
Datetime,%eventvalue%
Dondolo
#15 Post by Dondolo » 19 Dec 2021, 04:06
So everything is transmitted correctly and the receiver ESP can process it. Only the time is still an hour higher, maybe winter time or summer time?
SendToHTTP 192.168.178.107,80,"/control?cmd=event,ClockDate=%sysyear_0%-%sysmonth_0%-%sysday_0%,%syshour_0%:%sysmin_0%:%syssec_0%"
send ESP
send ESP
ESP recieve
ESP recieve
SysInfo
SysInfo
#16 Post by Ath » 19 Dec 2021, 09:58
The sending command includes 2 arguments, one for the date and the second for the time.
As the datetime command expects 2 arguments, you will have to pass these separately:
on DatumUhrzeit do
    Datetime,%eventvalue1%,%eventvalue2%
NB: %eventvalue% is equivalent to %eventvalue1%.
The 1 hour diff is probably caused by the time-zone you're in, CET? Or DST setting (though we're not in DST, currently).
#17 Post by TD-er » 19 Dec 2021, 14:11
The time stored in the RTC clock is in Unixtime.
And I doubt it is converting back using the current timezone and DST.
Not sure if the default should be to interpret it as "wall time" or "local time".
Usually the time source is some unit that's outputting Unix time, like NTP or a GPS.
igorka
#18 Post by igorka » 26 Oct 2022, 09:56
I ran into a problem, I can't configure the ESP to work with DS3231.
ESP-01S module (ESP_Easy_mega_20220616_normal_ESP8266_1M), RTC (HW-84) on a DS3231 chip.
In Tools/Time Source/External Time Source, I select DS3231.
I go to the Scan for I2C devices tab, there are, as it should be, two addresses on the I2C line. AT24C32 - 0x057 and DS3231 - 0x68.
But the Supported devices column is empty!?
In the Special and Experimental Settings/WD I2C Address, I set the address "104" (0x68).
Is it something I'm doing wrong, or do controllers with a small amount of memory (1M) not support this function?
#19 Post by Ath » 26 Oct 2022, 10:03
The Time Source and Watch Dog setting are in no way related, so please leave the WD setting at 0. It might unexpectedly reboot the unit.
Getting the Time Source to 'stick' (as in: actually use that Time Source) it expects the NTP setting to be off, and probably a few reboots.
igorka
#20 Post by igorka » 26 Oct 2022, 10:17
Ath wrote: 26 Oct 2022, 10:03 The Time Source and Watch Dog setting are in no way related, so please leave the WD setting at 0. It might unexpectedly reboot the unit.
Initially, I did not touch these settings, there was no difference. There is no DS3231 in Supported devices!
#21 Post by Ath » 26 Oct 2022, 10:34
The device names are removed in some builds (only available in Normal, Custom and Max, AFAIR) to save some .bin space. If the address is shown, a device is recognized, but unfortunately you can't see what (supported) device it is.
We have some plans to make that list external, but that's on low priority for now.
igorka
#22 Post by igorka » 26 Oct 2022, 10:44
Then the time synchronization from DS3231 should work correctly?Why doesn't it work for me?I ask for help, what settings do I need to make?Maybe I'm doing something wrong?
#23 Post by Ath » 26 Oct 2022, 10:52
You will need to set the date/time of the device correctly once it's configured, to have it stored: https://espeasy.readthedocs.io/en/lates ... l-commands
#24 Post by TD-er » 26 Oct 2022, 12:08
Does your DS3231 have a battery?
If the device is present, and set to use it as an external time source, the time will be stored in the external RTC chip as soon as the time is set on the ESP.
For example via NTP or using the command described here: https://espeasy.readthedocs.io/en/lates ... l-commands
You can simply test the RTC functionality by setting the date to something in the past, like 1/1/2022 or something which is clearly different from the current time.
Just make sure NTP is off and set the time via the datetime (and a battery is present in the RTC module)
Then power cycle the ESP and you should see the set time appear as system time in ESPEasy. (+ some minutes/seconds later)
In very recent builds (not sure if already present in the latest official build) you should also see a reported time source, like GPS, RTC, ext.RTC, NTP.
igorka
#25 Post by igorka » 26 Oct 2022, 12:18
Ath wrote: 26 Oct 2022, 10:52 You will need to set the date/time
Tools/Command Datetime,2022-10-26,12:03:00, Command Output OK.
System Info
System Info
After restarting the ESP, the time is lost:
System Info
System Info
Time Source
Time Source
The battery in the module is new, the voltage is 3V33, the voltage on the legs DS3231 is also normal, external power is also ok...
I conclude that my DS3231 module is faulty or defective.Unfortunately, I don't have an oscilloscope right now and I can't see if there is a signal on the 32 kHz pin.
igorka
#26 Post by igorka » 26 Oct 2022, 13:36
Could this problem be caused by the fact that I assigned GPIO1 to SDA(TX) and GPIO3 to SCL(RX)? Of course, in the Serial Settings, I removed the check mark from Enable Serial port, but maybe the module sends data to the Serial Port when loading, and therefore I'm not loading from the RTC module?
Changed SDA to GPIO2, no changes.Probably DS3231 is working (or partially working), because the scanner detects the address 0x68 i2c.
iog
iog
Ath wrote: 26 Oct 2022, 10:34 The device names are removed in some builds (only available in Normal, Custom and Max, AFAIR)
ESP_Easy_mega_20220616_normal_ESP8266_1M.
#27 Post by Ath » 26 Oct 2022, 16:40
igorka wrote: 26 Oct 2022, 13:36
Also excluded from 1M builds, didn't mention that, sorry :o
igorka
#28 Post by igorka » 26 Oct 2022, 17:28
I tried all pin combinations to connect i2c.When scanning the bus, it sees addresses, but it does not work to connect for time synchronization.Writes an error in the log as in the photo above.Maybe I should fill in another firmware for testing, and which one?
#29 Post by Ath » 26 Oct 2022, 17:50
Can you try that RTC on an ESP with more GPIOs, like a Wemos D1 (mini) or NodeMcu clone, to see if it actually works as intended? Also as the time-source? It's still possible the RTC is not working correctly.
igorka
#30 Post by igorka » 26 Oct 2022, 18:46
No, unfortunately, in the near future, I will not have such an opportunity.But I will definitely try to do it.
#31 Post by TD-er » 30 Oct 2022, 12:27
Just a quick update... I am currently working on the RTC implementation.
Though I don't have a DS3231 at hand, but am using a PCF8563.
I think the problem is not in the low level handling code of these RTC chips, but perhaps at another level.
Will update as soon as I have a test build for you.
igorka
#32 Post by igorka » 30 Oct 2022, 12:40
TD-er wrote: 30 Oct 2022, 12:27 Will update as soon as I have a test build for you.
Thanks! You are making a huge contribution to the development of ESP Easy.
#33 Post by TD-er » 30 Oct 2022, 13:18
When it has finished, can you check this test build: https://github.com/letscontrolit/ESPEas ... 3355411170
I also show the UTC time stored in the RTC chip on the tools->Advanced page and on the sysinfo page.
This can be useful for debugging.
igorka
#34 Post by igorka » 30 Oct 2022, 13:37
TD-er wrote: 30 Oct 2022, 13:18 When it has finished, can you check this test build: https://github.com/letscontrolit/ESPEas ... 3355411170
Of course I can.I have just one esp-01s board that is idle, for experiments.I'll try it during the next week, will it suit you?
#35 Post by TD-er » 30 Oct 2022, 13:43
Sure, whenever you're ready for it.
However, maybe there may have been newer commits added to it, so please check the Actions tab on GitHub for newer builds.
This is the related pull request: https://github.com/letscontrolit/ESPEasy/pull/4323
igorka
#36 Post by igorka » 31 Oct 2022, 14:54
I guess I'm too stupid.I can't figure out how to download the firmware file :cry:.If it's not difficult for you, give a direct link to the file for the ESP-01S board (ESP_Easy_mega_XXXXXX_ESP8266_1M.bin).
#37 Post by TD-er » 31 Oct 2022, 15:15
Just any 1M build?
igorka
#38 Post by igorka » 31 Oct 2022, 15:24
TD-er wrote: 31 Oct 2022, 15:15 Just any 1M build?
mega_ESP8266_1M.bin
Can you explain in private messages how to download from github?
#39 Post by TD-er » 31 Oct 2022, 15:24
Can you try this one?
https://www.dropbox.com/s/0u2nrnk4u26mr ... M.bin?dl=0
I just built it using the latest code changes I made less than an hour ago, regarding how the time is being dealt with in ESPEasy.
N.B. the "normal" 1M build was too big and thus doesn't fit. Have to look into that one too.
igorka
#40 Post by igorka » 31 Oct 2022, 19:17
Unfortunately, the result is negative.Similarly, when scanning the I2C bus, two addresses 0x57 and 0x68 (DS3231) are read.I set the system time with the Datetime command,2020-10-10,10:00:00, it is worth turning off the power and turning it on again, the time is not read from the RTC, ExtRTC: Cannot get time from external time source.
The connection was made like this:
GPIOO.0 - SDA
GPIO.2 - SCL
and vice versa
GPIOO.0 - SCL
GPIO.2 - SDA
The I2C scanner sees the addresses on the bus and that's it.
I wanted to try on the TX, RX pins, but they are programmatically disabled in the firmware.
#41 Post by Ath » 31 Oct 2022, 19:31
igorka wrote: 31 Oct 2022, 19:17 I wanted to try on the TX, RX pins, but they are programmatically disabled in the firmware.
If you uncheck the "Enable Serial port" option on the Tools/Advanced page, you can use those pins.
igorka
#42 Post by igorka » 01 Nov 2022, 08:28
Ath wrote: 31 Oct 2022, 19:31 If you uncheck the "Enable Serial port" option on the Tools/Advanced page, you can use those pins.
Yes, yes, you're right.I did it earlier and wrote about it, this is my mistake :cry: .
TD-er wrote: 31 Oct 2022, 15:24 Можете ли вы попробовать это?
Unfortunately, this did not help, the RTC does not work, perhaps this problem is only with DS3231?Another thing I noticed in Client IP filtering settings are not saved!Also, after a few minutes of operation, the ESP module loses connection with wi-fi and freezes :roll:
#43 Post by TD-er » 01 Nov 2022, 12:56
Hmm sounds like there might be something seriously wrong with your setup.
For example a loose ground?
No pull-up resistors on the SDA/SCL lines?
igorka
#44 Post by igorka » 01 Nov 2022, 13:19
TD-er wrote: 01 Nov 2022, 12:56 For example a loose ground?
No, that's out of the question.Everything is on soldering, there is good contact everywhere.This is a photo of a mock-up for experiments.I specially assigned SDA and SCL to the RX, TX contacts so that external components on the ESP-01S board would not interfere.
P.S.Deleted a photo that won't clog up the forum topic...
#45 Post by TD-er » 01 Nov 2022, 13:29
I just checked my order history on Ali Express and I should have these DS3231 boards somewhere.
I will search through all my boxes later this evening to find them and then I will check if the code is (still) working on those units.
igorka
#46 Post by igorka » 02 Nov 2022, 17:42
Sorry for the question. I wanted to know if you managed to start the DS3231 correctly?
#47 Post by TD-er » 02 Nov 2022, 19:02
I managed to find one... That's all I did with it right now.
igorka
#48 Post by igorka » 06 Nov 2022, 10:51
In the photo, there is a signal from the output 32K of the DS3231 module.Based on this, I am more and more inclined that the problems are in the firmware or ESP-01S.
Do not pay attention that the signal is bipolar, the oscilloscope input is closed.I forgot to turn it off...
#49 Post by TD-er » 08 Nov 2022, 00:08
Finally came to testing the board and it does work just fine on my test setup.
2022-11-08 00_07_15-MAX ESP32.png (9.08 KiB) Viewed 14180 times
Also tested with power cycle to be sure it wasn't set, tested to reboot and see what time source was reported.
And as can be seen on the screenshot, the tools->Advanced page does show what is stored inside the RTC module.
igorka
#50 Post by igorka » 08 Nov 2022, 08:24
This is good news for anyone who uses ESP Easy, but bad news specifically for me. For reference, which ESP controller card are you using and which pins are connected to the I2C bus?
Users browsing this forum: Google [Bot] and 24 guests
