timer problem
Cdrx34
timer problem
#1 Post by Cdrx34 » 03 Mar 2022, 09:25
Following the update of my esp8266 to the latest firmware, I find myself having a timer problem in a rules.
The timer runs fine but the timeout is not seconds:
If I put 4s I have about 15min
If I but 5s that this counts in several hours.
The NTP is apparently correctly configured, do you have an idea of ​​the problem?
Thanks in advance for your feedback.
Re: timer problem
#2 Post by Ath » 03 Mar 2022, 11:23
Please show your rules, so we can understand what you are doing there.
Cdrx34
Re: timer problem
#3 Post by Cdrx34 » 03 Mar 2022, 14:52
My project will allow the filling of a swimming pool automatically with a notification if the solenoid valve is driven too long.
on Niveau#Niveau = 1 do
	if [Notifuite#Alarme]=0
		gpio,14,1
		timerSet,1,120
on Niveau#Niveau = 0 do
		gpio,14,0
on Rules#Timer=1 do
	notify 1
	gpio,14,0
	TaskValueSet 11,2,1
endon[/i][/i]
iron
Re: timer problem
#4 Post by iron » 03 Mar 2022, 16:34
		gpio,14,0
There is an IF missing here. no ?
-D
Cdrx34
Re: timer problem
#5 Post by Cdrx34 » 03 Mar 2022, 17:28
No endif is too much, I had made modifications to try to solve my problem and I forgot to remove it
Re: timer problem
#6 Post by Ath » 03 Mar 2022, 21:23
I'd re-do the rules a bit, like this:
on Niveau#Niveau do
  if %eventvalue1%=1
    if [Notifuite#Alarme]=0 // When is this variable reset?
      gpio,14,1
      timerSet,1,120
    gpio,14,0
on Rules#Timer=1 do
  notify 1
  gpio,14,0
  TaskValueSet Notifuite,Alarme,1 // Names assumed correct?
Not sure if that TaskValueSet command is mapped right, but it's more readable and portable to use the names instead of the numbers.
Cdrx34
Re: timer problem
#7 Post by Cdrx34 » 03 Mar 2022, 23:08
Thanks for your feedback.
I will try this way.
The variable [Notifuite#Alarme] is reset by an Android application.
Cdrx34
Re: timer problem
#8 Post by Cdrx34 » 04 Mar 2022, 21:30
Still same problem with this code, the time is not in seconds.
