timer problem
timer problem
Following the update of my esp8266 to the latest firmware, I find myself having a timer problem in a rules.
The timer runs fine but the timeout is not seconds:
If I put 4s I have about 15min
If I but 5s that this counts in several hours.
The NTP is apparently correctly configured, do you have an idea of the problem?
Thanks in advance for your feedback.
Re: timer problem
Please show your rules, so we can understand what you are doing there.
Re: timer problem
My project will allow the filling of a swimming pool automatically with a notification if the solenoid valve is driven too long.
on Niveau#Niveau = 1 do
if [Notifuite#Alarme]=0
gpio,14,1
timerSet,1,120
on Niveau#Niveau = 0 do
gpio,14,0
on Rules#Timer=1 do
notify 1
gpio,14,0
TaskValueSet 11,2,1
endon[/i][/i]
Re: timer problem
gpio,14,0
-D
Re: timer problem
No endif is too much, I had made modifications to try to solve my problem and I forgot to remove it
Re: timer problem
I'd re-do the rules a bit, like this:
Not sure if that TaskValueSet command is mapped right, but it's more readable and portable to use the names instead of the numbers.
on Niveau#Niveau do
if %eventvalue1%=1
if [Notifuite#Alarme]=0 // When is this variable reset?
gpio,14,1
timerSet,1,120
gpio,14,0
on Rules#Timer=1 do
notify 1
gpio,14,0
TaskValueSet Notifuite,Alarme,1 // Names assumed correct?
Re: timer problem
Thanks for your feedback.
I will try this way.
The variable [Notifuite#Alarme] is reset by an Android application.
Re: timer problem
Still same problem with this code, the time is not in seconds.
