HELLO,
I created a virtual device
value 1: calculatee
value 2: effectuee
if to update it I use
taskValueSet,9,1,2515
taskValueSet,9,2,3025
It's OK
However, if I use
taskValueSet,DUREE_filtration,calculatee,2515
taskValueSet,DUREE_filtration,effecuee,3025
it does not work
please show me my mistake
TaskValueSet,TASKnr,VARnr,Value
Re: TaskValueSet,TASKnr,VARnr,Value
Where did you type those TaskValueSet commands?
And is there anything more around that code? (Please wrap your code using code tags for readability, using the '</>' button in the forum toolbar)
Wat version of ESPEasy is installed on your device? (Most explicit is the name of the .bin file you flashed)
And I assume the typo is 'effecuee' in because you re-typed it, not copy/pasted?
excuse english it's a google translation
I don't remember the .bin file
I realized the flash in January 2012 with this version:
ESP_Easy_mega_20210114_normal_ESP8285_1M
I am looking to change the code made at the time and use the name and value of the virtual device
Here is the code I am trying. I run using in the "TOOLS" tab
The virtual device is called "FILTRATION" and it has two values: calculatee "and "effectuee"
The command returns "OK" but does not change the values
Thank you for helping me
on filtration do
taskValueSet,FILTRATION,calculee,2020
taskValueSet,FILTRATION,effectuee,4500
Can you check on the Tools->Advanced page to make sure this checkbox is checked:
[x] Allow TaskValueSet on all plugins:
And when not sure about the syntax/names of the task and task values, you can always use the task index and taskvalue index (both starting at '1')
My current code uses indices. But they make code less understandable than name and value. It is for this reason that I seek to use them.
In the page "tools ->Advanced" I can't find
"Allow TaskValueSet on all plugins:"
Then you are on an old(er) version of ESPEasy that doesn't yet have that setting. Please update to the latest version, available from the Github releases page
Users browsing this forum: Anthropic Claude Bot [bot] and 16 guests
