Esp Easy max7219 Dot Matrix
is there a workaround to use the Max7219 Dot Matrix with Esp Easy?
Thanks Holgi
Thanks Holgi
Re: Esp Easy max7219 Dot Matrix
Almost three years later...
Has anyone had any success with this one?
/Anders
/Anders
Just a post to subscribe to this topic. I'm going to ask help for a project with that as well. Cheers.
Here:
viewtopic.php?f=2&t=8322
Here:
The plugin to support this type of display (P104) has been merged into the main development branch of ESPEasy (mega).
Today I downloaded release "ESPEasy_ESP82xx_mega-20211005" and flashed my D1 mini with the binary "ESP_Easy_mega_20211005_display_ESP8266_4M1M" but I didn't find the plugin for MAX7219 dot matrix. Isn't it included in the binaries yet?
The documentation for this plugin can be found on the site, though. https://espeasy.readthedocs.io/en/lates ... /P104.html
It hasn't been released yet. You can clone the repository and build it yourself, or get it from a Github Actions build of `mega`, or wait a few days for a release. I can build it for you and post here, but that will take until tomorrow evening (CET).
Thanks for the quick response and for the offer! I can wait until next release. I was so happy for the good news of this plugin that I wanted to test it right away but I don't have the time for this project right now anyway
You could try out the build I made yesterday for testing the scripts to generate the HTML for the (experimental) web flasher: https://td-er.nl/ESPEasy/
The code is based on what was yesterday the latest code. (probably still is)
Hey @all
my setup works very well (thanks to your help / I read this thread ...)
-Build: ESP_Easy_mega_20211105_display_ESP8266_4M1M Nov 5 2021
-MAX7219 2x4x
Is it possible to change the displayed text via a url command?
or is it planned for the future?
I'm not a programmer, (just a little VB) and have never had anything to do with Arduino before.
everything I have achieved so far only worked with this forum
Background:
I use Homematic (with the CCU2 & 3) and a (different) ESP for a status display.
Now I would like to use the MAX7219 panels for display too. The easiest way to do this is to use a url command ...
Sorry for my English, I'm from Germany and hope you still understand what I mean.
Thank you and best regards
CiciRs2006
-MAX7219 2x4x
Background:
CiciRs2006
Hi, and welcome
ESPEasy supports several ways to execute commands, as described on this page: https://espeasy.readthedocs.io/en/lates ... mmand.html (start reading at the top...
) then search for P104 (the plugin number, there's also a MAX7219 7 segment plugin, P073) to find all commands supported for the dotmatrix display.
Thank you very much, that was really very helpful. Exactly what I was looking for.
Now I still have the problem that the ESP sometimes freezes.
Then nothing works until I restart it several times.
Very often the device is then disabled and can only be set to enabled after several attempts.
Is that because the build version is still a test version?
P.S. "P104" is the right option for my setup.
Greetings and thank you
CiciRs2006
CiciRs2006
The 'test' in the build name used to indicate that it was indeed a test-version, but that label hasn't been applied that way for some time.
Usually, plugins are quite stable, though I haven't run this one for really long (like weeks) in a row, even though I did a lot of development on it.
Do you have log information from the unit (INFO level should be sufficient) around the time the freeze happens? Web logging won't be very reliable I assume as it will also freeze I guess, serial log or using a syslog server is quite reliable.
it is quite important that the power supply for the ESP is stable, separating it from the power for the displays is good idea (I did make that quite clear in the documentation), it is not unlikely that after some time the power supply becomes unstable because of the quite heavy load the display can put on it, I've been using a 5V 7A PSU, but it could only handle about 28 of these MAX7219 matrix modules.
Is the dot matrix task then disabled?
ESPEasy has a mechanism where it detects quick reboots.
After 10 of such incomplete boot sequences, it starts disabling tasks and then controllers, one by one.
So this may help prevent the ESP to remain inaccessible if a plugin or controller misbehaves (read: causes a crash)
If this happens to you, please share your configuration and/or how you interact with the task, e.g. via rules.
My wife said that when inside the swimming pool we cannot see what time it is.
With a lot of trials I succeded to use 2 Dot matrix with each 2 x 8 modules to display date, time and air and water temperature with following release
Build :ESP_Easy_mega_20220809_display_ESP8266_4M1M Aug 9 2022
All is done by mean of rules and at some times i use to give to ESPeasy a kind of french artificial intelligence see picture (french language)!!!!!
I would like now to play sounds at these particular times, but rtttl command is not valid and fails as the tone command is OK.
I think I will have to do my own build with also other plugins that I need.
Is somebody aware to explain what to do when building with PlatformIO to be sure that the rtttl command will be OK and not desabled as I read in some messages.
Many thanks for help
- Apero0b.jpg (46.75 KiB) Viewed 13250 times
- Apero1b.jpg (53.26 KiB) Viewed 13250 times
Great looking displays!
Suggested development environment is based on VSCode and PlatformIO. In this documentation page is a description on how to set up your local environment.
If you can't get that going, I could provide a custom build, if you list here what plugins and controllers you need.
Помогите подключить дисплей мах7219, у меня показывает мусор
Can you please post in English?
I just translated this using Google Translate:
How is it connected?Help me connect the max7219 display, it shows garbage
What kind of board do you use?
Which (exact) ESPEasy build do you use?
I have
Wemos D1 Mini and dot matrix display Max7219. When connected, it shows garbage. firmware mega-20211105
- IMG_20221103_182512.jpg (4.97 MiB) Viewed 13067 times
I am pretty sure something has been updated to this plugin in the last year.
So please try a newer build.
The latest one (very close to a new build) can be found here in the GitHub Actions:
https://github.com/letscontrolit/ESPEas ... 3384578967
N.B. You need to be logged in to GitHub to download the "Binaries" zip file from that page.
It looks like you are using the 7-segment display plugin using the display type MAX7219 (P073) instead of the required MAX7219 dot matrix plugin (P104) for this type of display. That last plugin (P104) is only available in the Display builds.
This has confused other users before (and was the original reason that P104 was created
installed HEAD_1a8947 (ESPEasy_display_ESP8266_4M1M) a no changes. maybe I downloaded the wrong firmware?TD-er wrote: ↑03 Nov 2022, 11:58 I am pretty sure something has been updated to this plugin in the last year.
I downloaded it doesn't workAth wrote: ↑03 Nov 2022, 13:08 It looks like you are using the 7-segment display plugin using the display type MAX7219 (P073) instead of the required MAX7219 dot matrix plugin (P104) for this type of display. That last plugin (P104) is only available in the Display builds.
This has confused other users before (and was the original reason that P104 was created).
Please show the Device configuration for your display.
- Безымянный4.jpg (3.01 MiB) Viewed 12964 times
- Безымянный3.jpg (26.62 KiB) Viewed 12993 times
- Безымянный.jpg (159.07 KiB) Viewed 12996 times
I think Ton also would like to see the pin configuration.
That's the 7-segment display plugin (P073), not the MAX7219 dot matrix plugin (P104), as I suggested could be the cause...
this is what need?
- Screenshot_2022-11-04-10-24-07-231_com.android.chrome.jpg (380.98 KiB) Viewed 12899 times
Sorry, can't read the Cyrillic characters, but from the few that aren't translated, it seems to be the correct plugin, as you will have seen by now, I assume
Offtopic:
Always seems kinda nice to see your own software being translated, even when it is automatically done in the browser.
It simply indicates its widely usage
Yes, SPI has to be enabled for this device to work.
That's exactly what it says, you have probably tried many options, and saved the settings often. To protect the flash, a warning is issued after a certain number of flash-writes has been reached, as flash memory wears out after a limited number of writes.
It's clear. How can I get 1820 sensor readings on this display?
The task you configured does have a name (e.g. "outdoor" or whatever name you entered)
The task value also has some name (e.g. "temperature" or whatever name you entered)
To use the current value of a taskvalue, you need to address it like this:
[taskname#taskvaluename] or using the names in my example: [outdoor#temperature]
=) worksTD-er wrote: ↑06 Nov 2022, 12:23 The task you configured does have a name (e.g. "outdoor" or whatever name you entered)
