error if and ife
error if and ife
now , i've no access
is there any way to get the access back?
thank you
Re: error if and ife
If that's in rules, it should be ignored, as that's an unknown command, it would be strange if that could block access to the ESP.
Do you have access to the serial log?
In what eventhandler is that code?, for a specific sensor, every minute using the on Clock#time=all,**:** do, or a system event like on system#boot do ?
Then controllers and as last resort disable all tasks and all controllers and the rules.
So if it has entered such a boot loop, it should after some time become available again with some parts disabled.
N.B. this will only be disabled in memory, so unless something is being saved, the process will be repeated the next time the ESP will reboot.
it reboot , reboot .....
Do you know what it tries to do to make it crash?
Tweaking the boot loop detection is for sure something I need to do, but maybe it is better to actually fix the crash reason
thank you very much
Can you share the Rules code that caused this boot loop? (if you don't want to publish here, a PM is also fine, for us to learn, and possibly prevent future issues)
origine :
On System#Boot Do
LoopTimerSet,1,900
On Rules#Timer=1 Do
If [Var#1]=1
GPIOToggle,14
Else
GPIO,14,1
On Clock#Time=All,**:** Do
If %syssec_d% > 36000 and %syssec_d% < 68400 //de 10h a 19h
Let,1,0 // 1 = pompe bassin en marche
Else
Let,1,0
Endif
On System#Boot Do
LoopTimerSet,1,900
On Rules#Timer=1 Do
If [Var#1]=1
GPIOToggle,14
Else
GPIO,14,1
Ife %syssec_d% > 36000 and %syssec_d% < 68400 //de 10h a 19h
Else
Let,1,0
Endif
On Rules#Timer=1 Do
If [Var#1]=1
GPIOToggle,14
Else
GPIO,14,1
Else
Let,1,0
Endif
Also this block doesn't "do" anything as both set the variable to the same value.
On Rules#Timer=1 Do
If [Var#1]=1
GPIOToggle,14
Else
GPIO,14,1
Let,1,0 // 1 = pump start 0 =pump stop
Else
Let,1,0
Endif
If %syssec_d% > 3600 and %syssec_d% < 28800//de 1h a 8h chaudiere
gpio,4,0
Else
gpio,4,1
Endif
//relais 2 pin 12 fontaine
// if %syssec_d% > 39600 and %syssec_d% < 72000 //de 11h a 20h
// gpio,12,0
// else
// gpio,12,1
// endif
//relais 1 pin 13 sonnette
if %syssec_d% > 28800 and %syssec_d% < 72000 //de 7h a 20h
gpio,13,0
//Publish,actions_bouton,sonnette_status#1
gpio,13,1
//Publish,actions_bouton,sonnette_status#2
if [rel2#Value1]=3
gpio,16,0
gpio,16,1
this is what I found the best to not put the relay "on" when I don't need it
that's why I had put " ife " instead of "if"
is there any other solution not to run a loop ?
without putting "//" on each line?
There is. You could add a variable check to all your if statements that need to be "switched" and declare this variable somewhere.
On System#Boot Do
Let,99,1 //change this to 0 to deactivate your statement
If [var#99]=1 and %syssec_d% > 36000 and %syssec_d% < 68400 //de 10h a 19h
Else
Let,1,0
Endif
Alternative would be to add an extra "if" around the code that is to be excluded.
True, but i thought thats what he wanted....
If [var#99]=1
Else
Let,1,0
Endif
Endif
where let variable if 0 = stop , 1 = forced work , automatique work
it's good for you ??
// relais
//1=13,2=12,3=14,4=16,5=4,6=5,7=3,8=1
Let,1,0
Let,2,0
Let,11,0 // relais 1 > 0 = arret , 1 = marche force , 2 = marche auto
Let,12,0 // relais 2 > 0 = arret , 1 = marche force , 2 = marche auto
Let,13,0 // relais 3 > 0 = arret , 1 = marche force , 2 = marche auto
Let,14,0 // relais 4 > 0 = arret , 1 = marche force , 2 = marche auto
Let,15,0 // relais 5 > 0 = arret , 1 = marche force , 2 = marche auto
Let,16,0 // relais 6 > 0 = arret , 1 = marche force , 2 = marche auto
Let,17,0 // relais 7 > 0 = arret , 1 = marche force , 2 = marche auto
Let,18,0 // relais 8 > 0 = arret , 1 = marche force , 2 = marche auto
On System#Boot Do
LoopTimerSet,1,900 //timer 15 minutes
On Rules#Timer=1 Do
If [Var#1]=1 // actif suivant heures
GPIOToggle,14 //marche arret 15 minutes
Else
GPIO,14,1
On Clock#Time=All,**:** Do // boucle suivant horaires
if [Var#11]=2 // relais 1 sonnette
gpio,13,0
gpio,13,1
if [Var#12]=2 // relais 2 fontaine auto
gpio,12,0
gpio,12,1
if [Var#13]=2 // relais 3 en auto pompe bassin
Let,1,1
Else
Let,1,0
Endif
if [Var#15]=2 //relais 5 en auto chaudiere
gpio,4,0
Else
gpio,4,1
Endif
if [Var#11]=0 //relais 1 stop
gpio,13,1
if [Var#11]=1 //relais 1 marche force
gpio,13,0
if [Var#12]=0 //relais 2 stop
gpio,12,1
if [Var#12]=1 //relais 2 marche force
gpio,12,0
if [Var#13]=0 //relais 3 stop
gpio,14,1
if [Var#13]=1 //relais 3 marche force
gpio,14,0
if [Var#14]=0 //relais 4 stop
gpio,16,1
if [Var#14]=1 //relais 4 marche force
gpio,16,0
if [Var#15]=0 //relais 5 stop
gpio,4,1
if [Var#15]=1 //relais 5 marche force
gpio,4,0
if [Var#16]=0 //relais 6 stop
gpio,5,1
if [Var#16]=1 //relais 6 marche force
gpio,5,0
if [Var#17]=0 //relais 7 stop
gpio,3,1
if [Var#17]=1 //relais 7 marche force
gpio,3,0
if [Var#18]=0 //relais 8 stop
gpio,1,1
if [Var#18]=1 //relais 8 marche force
gpio,1,0
gpio,13,1
gpio,13,0
if [Var#11]!=2 // not auto
gpio,13,![Var#11] // Inverted state
On Rules#Timer=1 Do
Else
GPIO,14,1
What if it is set to 0 elsewhere, then it would turn off when you wouldn't expect it to, so might be better to change that to gpio,14,0
that will lead to issues..
try this:
if [Var#11]=2 and %syssec_d% > 28800 and %syssec_d% < 72000 //auto mode
gpio,13,0
elseif [Var#11]=1 //always on
gpio,13,0
else //always off if var#11 anything is else than 2 or 1 or time is outside you defined area
gpio,13,1
Edit: Now i understand your code.. you declare all the values in rules at the beginning.. (and also there you need a ruleblock!) so maybe it doesn’t matter iff the change happens 1min later?
why 1min later?
On System#Boot Do
//declare the variables ar boot!!!
// relais
Let,1,0
Let,2,0
On Rules#Timer=1 Do
Else
GPIO,14,1
Endif
If [Var#11]=2 and %syssec_d% > 28800 and %syssec_d% < 72000 //auto mode
GPIO,13,0
Elseif [Var#11]=1 //always on
GPIO,13,0
Else //always off if var#11 anything is else than 2 or 1 or time is outside you defined area
GPIO,13,1
Endif
If [Var#12]=2 and %syssec_d% > 39600 and %syssec_d% < 72000 //de 11h a 20h
GPIO,12,0
Elseif [Var#12]=1
GPIO,12,0
Else
GPIO,12,1
Endif
If [Var#13]=2 and %syssec_d% > 36000 and %syssec_d% < 68400 //de 10h a 19h
GPIO,1,0
Elseif [Var#13]=1
GPIO,1,0
Else
GPIO,1,1
Endif
If [Var#15]=2 and %syssec_d% > 3600 and %syssec_d% < 28800//de 1h a 8h chaudiere
GPIO,4,0
Elseif [Var#15]=1
GPIO,4,0
Else
GPIO,4,1
Endif
On System#Boot Do
Let,16,1 // relais 6 > 0 = arret , 1 = marche force , 2 = marche auto
If [Var#16]=2 and %syssec_d% > 28800 and %syssec_d% < 72000 //auto mode
GPIO,5,0
Elseif [Var#16]=1 //always on
GPIO,5,0
GPIO,5,1
Endif
because this:
but you lost me with toggle
i want start and stop gpio 14 every 15 minutes of 10h am to 7h pm
the code work :
On System#Boot Do
LoopTimerSet,1,900
On Rules#Timer=1 Do
If [Var#1]=1
GPIOToggle,14
Else
GPIO,14,1
Else
Let,1,0
Endif[
endon/code]
On Rules#Timer=1 Do
If [Var#1]=1
GPIOToggle,14
Else
GPIO,14,1
ENDIF //important!!!!!!
On Rules#Timer=1 Do
If [Var#1]=1
GPIOToggle,14
Else
GPIO,14,1
Endif
Else
Let,1,0
Endif
If [Var#1]=1
GPIOToggle,14
On Rules#Timer=1 Do
If [Var#1]=1
GPIOToggle,14
Else
GPIO,14,1
Endif
Let,1,1 // 1 = pompe bassin en marche
Else
Let,1,0
Endif
if [Var#13]=2 and %syssec_d% > 36000 and %syssec_d% < 68400 //de 10h a 19h
Let,1,1
elseif [Var#12]=1
gpio,14,0
Else
Let,1,0
Endif
Let,1,1
elseif [Var#12]=1
gpio,14,0
Else
Let,1,0
Endif
This will work....bledad wrote: ↑21 Nov 2022, 15:56 sorry , another bad paste
On Rules#Timer=1 Do If [Var#1]=1 GPIOToggle,14 Else GPIO,14,1 Endif Endon On Clock#Time=All,**:** Do If %syssec_d% > 36000 and %syssec_d% < 68400 //de 10h a 19h Let,1,1 // 1 = pompe bassin en marche Else Let,1,0 Endif Endon
yes, with some minor changes
Let,1,1
Elseif [Var#13]=1 //< i guess this should be var#13 instead of var#12
gpio,14,0
Else
Let,1,0
Endif
you can verifier the final code ?
// relais
Let,1,0
Let,2,0
Let,11,0 // relais 1 > 0 = arret , 1 = marche force , 2 = marche auto sonnette
Let,12,0 // relais 2 > 0 = arret , 1 = marche force , 2 = marche auto fontaine
Let,13,0 // relais 3 > 0 = arret , 1 = marche force , 2 = marche auto bassin
Let,15,0 // relais 5 > 0 = arret , 1 = marche force , 2 = marche auto chaudiere
On System#Boot Do
On Rules#Timer=1 Do
Else
GPIO,14,1
gpio,13,0
gpio,13,0
else //always off if var#11 anything else than 2 or 1
gpio,13,1
//relais 2 fontaine
if [Var#12]=2 and %syssec_d% > 39600 and %syssec_d% < 72000 //de 11h a 20h
gpio,12,0
elseif [Var#12]=1
gpio,12,0
gpio,12,1
//relais 3 pompe bassin
Let,1,1
elseif [Var#13]=1
gpio,14,0
Else
gpio,14,1
Endif
//relais 4
if [Var#14]=2 and %syssec_d% > 3600 and %syssec_d% < 28800//
gpio,16,0
elseif [Var#14]=1
gpio,16,0
Else
gpio,16,1
//relais 5 chaudiere ete hiver
if [Var#15]=2 and %syssec_d% > 3600 and %syssec_d% < 28800//de 1h a 8h chaudiere
gpio,4,0
elseif [Var#15]=1
gpio,4,0
Else
gpio,4,1
//relais 6
if [Var#16]=2 and %syssec_d% > 3600 and %syssec_d% < 28800//
gpio,5,0
elseif [Var#16]=1
gpio,5,0
Else
gpio,5,1
//relais 7
if [Var#17]=2 and %syssec_d% > 3600 and %syssec_d% < 28800//
gpio,3,0
elseif [Var#17]=1
gpio,3,0
Else
gpio,3,1
//relais 8
if [Var#18]=2 and %syssec_d% > 3600 and %syssec_d% < 28800//
gpio,1,0
elseif [Var#18]=1
gpio,1,0
Else
gpio,1,1
Rules act on events, so have to be in blocks like these:
on ... do
On System#Boot Do
// relais
Let,1,0
Let,2,0
On Rules#Timer=1 Do
If [Var#1]=2
GPIOToggle,14
Elseif [Var#1]=0
GPIO,14,1
Endif
gpio,13,0
gpio,13,0
gpio,13,1
//relais 2 fontaine
gpio,12,0
elseif [Var#12]=1
gpio,12,0
gpio,12,1
Let,1,2
gpio,14,0
Let,1,1
Else
Let,1,0
Endif
//relais 4
gpio,16,0
elseif [Var#14]=1
gpio,16,0
Else
gpio,16,1
gpio,4,0
elseif [Var#15]=1
gpio,4,0
Else
gpio,4,1
//relais 6
gpio,5,0
elseif [Var#16]=1
gpio,5,0
Else
gpio,5,1
//relais 7
gpio,3,0
elseif [Var#17]=1
gpio,3,0
Else
gpio,3,1
//relais 8
gpio,1,0
elseif [Var#18]=1
gpio,1,0
Else
gpio,1,1
Thats why it is so helpful, to give the whole picture of what you want to do...
And if you are not good with code you can always tell us with your own words what should happen/ what you want to achieve .
On System#Boot Do
// relais
Let,1,0
Let,2,0
On Rules#Timer=1 Do
If [Var#1]=2
GPIOToggle,14
Elseif [Var#1]=0
GPIO,14,1
Endif
gpio,13,0
gpio,13,0
gpio,13,1
//relais 2 fontaine
gpio,12,0
elseif [Var#12]=1
gpio,12,0
gpio,12,1
Let,1,2
Elseif [Var#13]=1
gpio,14,0
Let,1,1
Else
Let,1,0
Endif
//relais 4
gpio,16,0
elseif [Var#14]=1
gpio,16,0
Else
gpio,16,1
gpio,4,0
elseif [Var#15]=1
gpio,4,0
Else
gpio,4,1
//relais 6
gpio,5,0
elseif [Var#16]=1
gpio,5,0
Else
gpio,5,1
//relais 7
gpio,3,0
elseif [Var#17]=1
gpio,3,0
Else
gpio,3,1
//relais 8
gpio,1,0
elseif [Var#18]=1
gpio,1,0
Else
gpio,1,1
How are the variables being set after the unit boots? Some other events?
You can set variables via commands or other events. No need to reboot for each test.
However, I would like to know what you're trying to achieve here.
You can run the command
event,system#boot
On System#Boot Do
Let,1,0
Let,2,0
LoopTimerSet,2,5 //timer 5 seconds
On Rules#Timer=2 Do
// relais
be able to modify the action of each relay , ( on , off , on auto with schedule )
For example:
- relais 1
- GPIO 13, inverted logic: "0" is "on"
- When: %syssec_d% > 28800 and %syssec_d% < 72000
There also seems to be some variable # 11, which does seem to indicate the following:
- [Var#11]=0 //always off
- [Var#11]=1 //always on
- [Var#11]=2 //Timer mode
That's what I am reading in this rules code:
gpio,13,0
gpio,13,0
gpio,13,1
- relais 1
- forced on without %syssec_d% > 28800 and %syssec_d% < 72000
- forced off without %syssec_d% > 28800 and %syssec_d% < 72000
and for
- relais 3
- same thing
- add stop and start every 15 min. when %syssec_d% > 36000 and %syssec_d% < 68400
else //always off if var#11 anything else than 2 or 1 or %syssec_d% is outside the defined area
then the code i send you should work.For example:
- relais 1
and for
- relais 3
- same thing
can you test it and report?
Edit: here the whole thing with the latest change:
On System#Boot Do
Let,1,0
Let,2,0
On Rules#Timer=2 Do
// relais
On Rules#Timer=1 Do
If [Var#1]=2
GPIOToggle,14
Elseif [Var#1]=0
GPIO,14,1
Endif
gpio,13,0
gpio,13,0
gpio,13,1
//relais 2 fontaine
gpio,12,0
elseif [Var#12]=1
gpio,12,0
gpio,12,1
Let,1,2
gpio,14,0
Let,1,1
Else
Let,1,0
Endif
//relais 4
gpio,16,0
elseif [Var#14]=1
gpio,16,0
Else
gpio,16,1
gpio,4,0
elseif [Var#15]=1
gpio,4,0
Else
gpio,4,1
//relais 6
gpio,5,0
elseif [Var#16]=1
gpio,5,0
Else
gpio,5,1
//relais 7
gpio,3,0
elseif [Var#17]=1
gpio,3,0
Else
gpio,3,1
//relais 8
gpio,1,0
elseif [Var#18]=1
gpio,1,0
Else
gpio,1,1
On Rules#Timer=2 Do
On System#Boot Do
Let,1,0
Let,2,0
On Rules#Timer=1 Do
If [Var#1]=2
GPIOToggle,14
Elseif [Var#1]=0
GPIO,14,1
Endif
On Rules#Timer=2 Do
// relais
gpio,13,0
gpio,13,0
gpio,13,1
//relais 2 fontaine
gpio,12,0
elseif [Var#12]=1
gpio,12,0
gpio,12,1
Let,1,2
gpio,14,0
Let,1,1
Else
Let,1,0
Endif
//relais 4
gpio,16,0
elseif [Var#14]=1
gpio,16,0
Else
gpio,16,1
gpio,4,0
elseif [Var#15]=1
gpio,4,0
Else
gpio,4,1
//relais 6
gpio,5,0
elseif [Var#16]=1
gpio,5,0
Else
gpio,5,1
//relais 7
gpio,3,0
elseif [Var#17]=1
gpio,3,0
Else
gpio,3,1
//relais 8
gpio,1,0
elseif [Var#18]=1
gpio,1,0
Else
gpio,1,1
It needs to toggle some relais at 15 min interval.
Users browsing this forum: Anthropic Claude Bot [bot], OpenAI GPTBot [bot], opensiteexplorer.org/dotbot [bot] and 33 guests
