error if and ife
bledad
error if and ife
#1 Post by bledad » 19 Nov 2022, 16:45
hello, on esp8266 i have do a error , i have put ife instead if
now , i've no access
is there any way to get the access back?
thank you
Re: error if and ife
#2 Post by Ath » 19 Nov 2022, 16:49
Where did you put that 'ife'?
If that's in rules, it should be ignored, as that's an unknown command, it would be strange if that could block access to the ESP.
Do you have access to the serial log?
bledad
#3 Post by bledad » 19 Nov 2022, 16:51
yes in the rules , i've no access at serial log
#4 Post by Ath » 19 Nov 2022, 17:16
What is happening if the lines after the wrong ife statement are executed?
In what eventhandler is that code?, for a specific sensor, every minute using the on Clock#time=all,**:** do, or a system event like on system#boot do ?
#5 Post by TD-er » 19 Nov 2022, 17:25
When the ESP may enter some kind of "boot loop" and thus never really completes a boot, it will start disabling tasks one by one.
Then controllers and as last resort disable all tasks and all controllers and the rules.
So if it has entered such a boot loop, it should after some time become available again with some parts disabled.
N.B. this will only be disabled in memory, so unless something is being saved, the process will be repeated the next time the ESP will reboot.
bledad
#6 Post by bledad » 19 Nov 2022, 17:37
in Clock#time=all,**:** do
it reboot , reboot .....
#7 Post by TD-er » 19 Nov 2022, 18:41
Ah that's indeed something that won't be detected by that algorithm.
Do you know what it tries to do to make it crash?
Tweaking the boot loop detection is for sure something I need to do, but maybe it is better to actually fix the crash reason ;)
bledad
#8 Post by bledad » 20 Nov 2022, 11:42
ok , the algorithm is good , it took a long time , I was able to access it and correct the error
thank you very much
#9 Post by Ath » 20 Nov 2022, 13:27
Ah, great, the safety measures work as intended.
Can you share the Rules code that caused this boot loop? (if you don't want to publish here, a PM is also fine, for us to learn, and possibly prevent future issues)
bledad
#10 Post by bledad » 20 Nov 2022, 13:39
no problem :
origine :
On System#Boot Do
	LoopTimerSet,1,900
On Rules#Timer=1 Do
	If [Var#1]=1
		GPIOToggle,14
    	Else
    		GPIO,14,1
On Clock#Time=All,**:** Do
  	If  %syssec_d% > 36000 and %syssec_d% < 68400 //de 10h a 19h
        	Let,1,0 // 1 = pompe bassin en marche
   	Else
        	Let,1,0
  	Endif
modif :
On System#Boot Do
	LoopTimerSet,1,900
On Rules#Timer=1 Do
	If [Var#1]=1
		GPIOToggle,14
    	Else
    		GPIO,14,1
  	Ife  %syssec_d% > 36000 and %syssec_d% < 68400 //de 10h a 19h
   	Else
        	Let,1,0
  	Endif
#11 Post by TD-er » 20 Nov 2022, 21:03
There are other issues too...
On Rules#Timer=1 Do
	If [Var#1]=1
		GPIOToggle,14
    	Else
    		GPIO,14,1
Missing an "endif" before the "endon"
   	Else
        	Let,1,0
  	Endif
Missing an "endon"
Also this block doesn't "do" anything as both set the variable to the same value.
bledad
#12 Post by bledad » 21 Nov 2022, 09:43
yes , hi have missing endif , but it works !!
On Rules#Timer=1 Do
	If [Var#1]=1
		GPIOToggle,14
    	Else
    		GPIO,14,1
for this :
        	Let,1,0 // 1 = pump start  0 =pump stop
   	Else
        	Let,1,0
  	Endif
  	If  %syssec_d% > 3600 and %syssec_d% < 28800//de 1h a 8h chaudiere
                gpio,4,0
   	Else
        	gpio,4,1
  	Endif
//relais 2 pin 12 fontaine
  // if  %syssec_d% > 39600 and %syssec_d% < 72000 //de 11h a 20h
  //   gpio,12,0
 //  else
 //    gpio,12,1
 //  endif
//relais 1 pin 13 sonnette
   if  %syssec_d% > 28800 and %syssec_d% < 72000 //de 7h a 20h
     gpio,13,0
     //Publish,actions_bouton,sonnette_status#1
     gpio,13,1
     //Publish,actions_bouton,sonnette_status#2
   if [rel2#Value1]=3
     gpio,16,0
     gpio,16,1
I had not put all , i set the variable to the same value , because i stop with 0 or start with 1
this is what I found the best to not put the relay "on" when I don't need it
that's why I had put " ife " instead of "if"
is there any other solution not to run a loop ?
without putting "//" on each line?
chromo23
#13 Post by chromo23 » 21 Nov 2022, 09:58
bledad wrote: 21 Nov 2022, 09:43 is there any other solution not to run a loop ?
There is. You could add a variable check to all your if statements that need to be "switched" and declare this variable somewhere.
On System#Boot Do
	Let,99,1 //change this to 0 to deactivate your statement
  	If  [var#99]=1 and %syssec_d% > 36000 and %syssec_d% < 68400 //de 10h a 19h
   	Else
        	Let,1,0
  	Endif
Edit: advantage of that is, that you can control this with commands via http or other protocols
bledad
#14 Post by bledad » 21 Nov 2022, 10:03
yes good idea
#15 Post by Ath » 21 Nov 2022, 10:09
Disadvantage of that it will always execute the "else" part of the code, that may not be what you want...
Alternative would be to add an extra "if" around the code that is to be excluded.
bledad
#16 Post by bledad » 21 Nov 2022, 10:13
?? ,example , because i do google translate , my english is very bad
chromo23
#17 Post by chromo23 » 21 Nov 2022, 10:18
Ath wrote: 21 Nov 2022, 10:09 Disadvantage of that it will always execute the "else" part
True, but i thought thats what he wanted....
bledad wrote: 21 Nov 2022, 10:13example
   If  [var#99]=1
   	Else
        	Let,1,0
  	Endif
   Endif
bledad
#18 Post by bledad » 21 Nov 2022, 14:32
hi , thank you , i've redone my rules for 8 relay
where let variable if 0 = stop , 1 = forced work , automatique work
it's good for you ??
// relais
//1=13,2=12,3=14,4=16,5=4,6=5,7=3,8=1
Let,1,0
Let,2,0
Let,11,0 // relais 1 > 0 = arret , 1 = marche force , 2 = marche auto
Let,12,0 // relais 2 > 0 = arret , 1 = marche force , 2 = marche auto
Let,13,0 // relais 3 > 0 = arret , 1 = marche force , 2 = marche auto
Let,14,0 // relais 4 > 0 = arret , 1 = marche force , 2 = marche auto
Let,15,0 // relais 5 > 0 = arret , 1 = marche force , 2 = marche auto
Let,16,0 // relais 6 > 0 = arret , 1 = marche force , 2 = marche auto
Let,17,0 // relais 7 > 0 = arret , 1 = marche force , 2 = marche auto
Let,18,0 // relais 8 > 0 = arret , 1 = marche force , 2 = marche auto
On System#Boot Do
	LoopTimerSet,1,900 //timer 15 minutes
On Rules#Timer=1 Do
	If [Var#1]=1 // actif suivant heures
		GPIOToggle,14 //marche arret 15 minutes
    Else
    	GPIO,14,1
On Clock#Time=All,**:** Do // boucle suivant horaires
	if [Var#11]=2 // relais 1  sonnette
			gpio,13,0
			gpio,13,1
	if [Var#12]=2 // relais 2 fontaine auto
			gpio,12,0
			gpio,12,1
    if [Var#13]=2 // relais 3 en auto pompe bassin
        	Let,1,1
   	    Else
        	Let,1,0
  	    Endif
	if [Var#15]=2 //relais 5 en auto chaudiere
            gpio,4,0
   	    Else
        	gpio,4,1
  	Endif
if [Var#11]=0 //relais 1 stop
   gpio,13,1
if [Var#11]=1 //relais 1 marche force
   gpio,13,0
if [Var#12]=0 //relais 2 stop
   gpio,12,1
if [Var#12]=1 //relais 2 marche force
   gpio,12,0
if [Var#13]=0 //relais 3 stop
   gpio,14,1
if [Var#13]=1 //relais 3 marche force
   gpio,14,0
if [Var#14]=0 //relais 4 stop
   gpio,16,1
if [Var#14]=1 //relais 4 marche force
   gpio,16,0
if [Var#15]=0 //relais 5 stop
   gpio,4,1
if [Var#15]=1 //relais 5 marche force
   gpio,4,0
if [Var#16]=0 //relais 6 stop
   gpio,5,1
if [Var#16]=1 //relais 6 marche force
   gpio,5,0
if [Var#17]=0 //relais 7 stop
   gpio,3,1
if [Var#17]=1 //relais 7 marche force
   gpio,3,0
if [Var#18]=0 //relais 8 stop
   gpio,1,1
if [Var#18]=1 //relais 8 marche force
   gpio,1,0
#19 Post by Ath » 21 Nov 2022, 14:45
You have a lot of these:
   gpio,13,1
   gpio,13,0
I think that can be shorter, and thus faster to process like this:
if [Var#11]!=2 // not auto
   gpio,13,![Var#11] // Inverted state
Also, this part might not always work as intended:
On Rules#Timer=1 Do
  Else
    GPIO,14,1
The GPIOToggle will do exactly that, toggle the state from 1 to 0 or from 0 to 1.
What if it is set to 0 elsewhere, then it would turn off when you wouldn't expect it to, so might be better to change that to gpio,14,0
chromo23
#20 Post by chromo23 » 21 Nov 2022, 14:50
Not quite.. the last part is outside a ruleblock (on-do-endon)
that will lead to issues..
try this:
	if [Var#11]=2 and  %syssec_d% > 28800 and %syssec_d% < 72000 	//auto mode
	  gpio,13,0
     	elseif [Var#11]=1  	//always on
	 gpio,13,0
        else 				//always off if var#11 anything is else than 2 or 1 or time is outside you defined area
         gpio,13,1
Edit: maybe ignore this code. It works only once a minute... so when changing var#11 the change will physically appear worst case 1min after.
Edit: Now i understand your code.. you declare all the values in rules at the beginning.. (and also there you need a ruleblock!) so maybe it doesn’t matter iff the change happens 1min later?
bledad
#21 Post by bledad » 21 Nov 2022, 15:06
ok , i understand
why 1min later?
chromo23
#22 Post by chromo23 » 21 Nov 2022, 15:11
This could be it:
On System#Boot Do
  //declare the variables ar boot!!!
  // relais
  Let,1,0
  Let,2,0
On Rules#Timer=1 Do
  	Else
    		GPIO,14,1
	Endif
	If [Var#11]=2 and  %syssec_d% > 28800 and %syssec_d% < 72000 	//auto mode
	  GPIO,13,0
  	Elseif [Var#11]=1  	//always on
	  GPIO,13,0
  	Else 				//always off if var#11 anything is else than 2 or 1 or time is outside you defined area
   	  GPIO,13,1
	Endif
  	If [Var#12]=2 and  %syssec_d% > 39600 and %syssec_d% < 72000 //de 11h a 20h
	  GPIO,12,0
  	Elseif [Var#12]=1
	  GPIO,12,0
  	Else
   	  GPIO,12,1
	Endif
	If [Var#13]=2 and %syssec_d% > 36000 and %syssec_d% < 68400 //de 10h a 19h
	  GPIO,1,0
  	Elseif [Var#13]=1
	  GPIO,1,0
  	Else
          GPIO,1,1
	Endif
   	If [Var#15]=2 and %syssec_d% > 3600 and %syssec_d% < 28800//de 1h a 8h chaudiere
	  GPIO,4,0
  	Elseif [Var#15]=1
	  GPIO,4,0
  	Else
   	  GPIO,4,1
	Endif
bledad
#23 Post by bledad » 21 Nov 2022, 15:16
yes ok , but if , by example , i want start relay 6 ( gpio 5 ) with Let variable without time ?,
chromo23
#24 Post by chromo23 » 21 Nov 2022, 15:20
bledad wrote: 21 Nov 2022, 15:16 yes ok , but if , by example , i want start relay 6 ( gpio 5 ) with Let variable without time ?,
On System#Boot Do
  Let,16,1 // relais 6 > 0 = arret , 1 = marche force , 2 = marche auto
	If [Var#16]=2 and  %syssec_d% > 28800 and %syssec_d% < 72000 	//auto mode
	  GPIO,5,0
       	Elseif [Var#16]=1  	//always on
	  GPIO,5,0
         GPIO,5,1
       	Endif
chromo23
#25 Post by chromo23 » 21 Nov 2022, 15:24
bledad wrote: 21 Nov 2022, 15:06 ok , i understand
why 1min later?
because this:
checks only every minute which state your variable has...
chromo23
#26 Post by chromo23 » 21 Nov 2022, 15:27
Maybe it is also good to explain as good as possible what you want to do. This makes helping you a lot easier. (you can use pseudo code if you want)
bledad
#27 Post by bledad » 21 Nov 2022, 15:37
ok for 1 minute
but you lost me with toggle
i want start and stop gpio 14 every 15 minutes of 10h am to 7h pm
the code work :
On System#Boot Do
	LoopTimerSet,1,900
On Rules#Timer=1 Do
	If [Var#1]=1
		GPIOToggle,14
    	Else
    		GPIO,14,1
   	Else
        	Let,1,0
  	Endif[
endon/code]
chromo23
#28 Post by chromo23 » 21 Nov 2022, 15:46
Do not forget to close a rulesblock or if-statements!!!!!!
On Rules#Timer=1 Do
	If [Var#1]=1
		GPIOToggle,14
    	Else
    		GPIO,14,1
       ENDIF  //important!!!!!!
bledad
#29 Post by bledad » 21 Nov 2022, 15:49
ok ,sorry , I had modified in my code, but not in the paste
chromo23
#30 Post by chromo23 » 21 Nov 2022, 15:50
And this can not work:
On Rules#Timer=1 Do
	If [Var#1]=1
		GPIOToggle,14
    	Else
    		GPIO,14,1
    	Endif
   	Else
        	Let,1,0
  	Endif
because after one minute var#1 will be 0 and this will never happen:
If [Var#1]=1
	GPIOToggle,14
bledad
#31 Post by bledad » 21 Nov 2022, 15:56
sorry , another bad paste
On Rules#Timer=1 Do
	If [Var#1]=1
		GPIOToggle,14
    	Else
    		GPIO,14,1
    	Endif
        	Let,1,1 // 1 = pompe bassin en marche
   	Else
        	Let,1,0
  	Endif
bledad
#32 Post by bledad » 21 Nov 2022, 16:01
with the toggle code , this ( with new code ), it's good ?
 if [Var#13]=2 and  %syssec_d% > 36000 and %syssec_d% < 68400 //de 10h a 19h
        	Let,1,1
        elseif [Var#12]=1
			gpio,14,0
   	    Else
        	Let,1,0
  	    Endif
#33 Post by TD-er » 21 Nov 2022, 16:05
You have one endif too many in your piece of code:
  Let,1,1
elseif [Var#12]=1
  gpio,14,0
Else
  Let,1,0
Endif
N.B. have not looked at what you're trying to do here, only looked at the syntax and matching if/endif
chromo23
#34 Post by chromo23 » 21 Nov 2022, 16:40
bledad wrote: 21 Nov 2022, 15:56 sorry , another bad paste
On Rules#Timer=1 Do
	If [Var#1]=1
		GPIOToggle,14
    	Else
    		GPIO,14,1
    	Endif
   	Else
        	Let,1,0
  	Endif
This will work....
bledad wrote: 21 Nov 2022, 16:01 with the toggle code , this ( with new code ), it's good ?
yes, with some minor changes
  Let,1,1
Elseif [Var#13]=1 //< i guess this should be var#13 instead of var#12
  gpio,14,0
Else
  Let,1,0
Endif
bledad
#35 Post by bledad » 21 Nov 2022, 16:54
yes , than you
you can verifier the final code ?
// relais
Let,1,0
Let,2,0
Let,11,0 // relais 1 > 0 = arret , 1 = marche force , 2 = marche auto sonnette
Let,12,0 // relais 2 > 0 = arret , 1 = marche force , 2 = marche auto fontaine
Let,13,0 // relais 3 > 0 = arret , 1 = marche force , 2 = marche auto bassin
Let,15,0 // relais 5 > 0 = arret , 1 = marche force , 2 = marche auto chaudiere
On System#Boot Do
On Rules#Timer=1 Do
    Else
    	GPIO,14,1
		gpio,13,0
		gpio,13,0
    else 				//always off if var#11 anything else than 2 or 1
        gpio,13,1
	//relais 2 fontaine
	if [Var#12]=2 and %syssec_d% > 39600 and %syssec_d% < 72000 //de 11h a 20h
		gpio,12,0
	elseif [Var#12]=1
		gpio,12,0
		gpio,12,1
	//relais 3 pompe bassin
       	Let,1,1
    elseif [Var#13]=1
		gpio,14,0
   	Else
       	gpio,14,1
  	Endif
	//relais 4
	if [Var#14]=2 and %syssec_d% > 3600 and %syssec_d% < 28800//
		gpio,16,0
	elseif [Var#14]=1
		gpio,16,0
   	Else
       	gpio,16,1
	//relais 5 chaudiere ete hiver
	if [Var#15]=2 and %syssec_d% > 3600 and %syssec_d% < 28800//de 1h a 8h chaudiere
        gpio,4,0
	elseif [Var#15]=1
		gpio,4,0
   	Else
       	gpio,4,1
	//relais 6
	if [Var#16]=2 and %syssec_d% > 3600 and %syssec_d% < 28800//
        gpio,5,0
	elseif [Var#16]=1
		gpio,5,0
    Else
       	gpio,5,1
	//relais 7
	if [Var#17]=2 and %syssec_d% > 3600 and %syssec_d% < 28800//
        gpio,3,0
	elseif [Var#17]=1
		gpio,3,0
    Else
       	gpio,3,1
	//relais 8
	if [Var#18]=2 and %syssec_d% > 3600 and %syssec_d% < 28800//
        gpio,1,0
	elseif [Var#18]=1
		gpio,1,0
	Else
       	gpio,1,1
#36 Post by TD-er » 21 Nov 2022, 16:57
Those let calls at the begin will not be used or executed.
Rules act on events, so have to be in blocks like these:
on ... do
chromo23
#37 Post by chromo23 » 21 Nov 2022, 17:13
Maybe this is it?
On System#Boot Do
  // relais
  Let,1,0
  Let,2,0
On Rules#Timer=1 Do
  If [Var#1]=2
    GPIOToggle,14
  Elseif [Var#1]=0
    GPIO,14,1
  Endif
    gpio,13,0
    gpio,13,0
    gpio,13,1
	//relais 2 fontaine
    gpio,12,0
  elseif [Var#12]=1
    gpio,12,0
    gpio,12,1
    Let,1,2
    gpio,14,0
    Let,1,1
  Else
    Let,1,0
  Endif
	//relais 4
    gpio,16,0
  elseif [Var#14]=1
    gpio,16,0
  Else
    gpio,16,1
    gpio,4,0
  elseif [Var#15]=1
    gpio,4,0
  Else
   gpio,4,1
	//relais 6
    gpio,5,0
  elseif [Var#16]=1
    gpio,5,0
  Else
    gpio,5,1
	//relais 7
    gpio,3,0
  elseif [Var#17]=1
    gpio,3,0
  Else
    gpio,3,1
	//relais 8
    gpio,1,0
  elseif [Var#18]=1
    gpio,1,0
  Else
    gpio,1,1
bledad
#38 Post by bledad » 21 Nov 2022, 17:18
I had thought about it , but i will have to reboot at each variable change ?
chromo23
#39 Post by chromo23 » 21 Nov 2022, 17:22
bledad wrote: 21 Nov 2022, 17:18 I had thought about it , but i will have to reboot at each variable change ?
Thats why it is so helpful, to give the whole picture of what you want to do...
And if you are not good with code you can always tell us with your own words what should happen/ what you want to achieve .
#40 Post by TD-er » 21 Nov 2022, 17:23
I did format the code a bit more so it is readable with consistent indents:
On System#Boot Do
  // relais
  Let,1,0
  Let,2,0
On Rules#Timer=1 Do
  If [Var#1]=2
    GPIOToggle,14
  Elseif [Var#1]=0
    GPIO,14,1
  Endif
    gpio,13,0
    gpio,13,0
    gpio,13,1
  //relais 2 fontaine
    gpio,12,0
  elseif [Var#12]=1
    gpio,12,0
    gpio,12,1
    Let,1,2
  Elseif [Var#13]=1
    gpio,14,0
    Let,1,1
  Else
    Let,1,0
  Endif
  //relais 4
    gpio,16,0
  elseif [Var#14]=1
    gpio,16,0
  Else
    gpio,16,1
    gpio,4,0
  elseif [Var#15]=1
    gpio,4,0
  Else
    gpio,4,1
  //relais 6
    gpio,5,0
  elseif [Var#16]=1
    gpio,5,0
  Else
    gpio,5,1
  //relais 7
    gpio,3,0
  elseif [Var#17]=1
    gpio,3,0
  Else
    gpio,3,1
  //relais 8
    gpio,1,0
  elseif [Var#18]=1
    gpio,1,0
  Else
    gpio,1,1
But it is a bit unclear to me what you want to do here.
How are the variables being set after the unit boots? Some other events?
You can set variables via commands or other events. No need to reboot for each test.
However, I would like to know what you're trying to achieve here.
#41 Post by Ath » 21 Nov 2022, 17:24
You can run the command
event,system#boot
from the Tools page, that will only run the rule, no other stuff, unless you added that in the rules
chromo23
#42 Post by chromo23 » 21 Nov 2022, 17:25
You could change the code to this:
On System#Boot Do
  Let,1,0
  Let,2,0
  LoopTimerSet,2,5 //timer 5 seconds
On Rules#Timer=2 Do
  // relais
chromo23
#43 Post by chromo23 » 21 Nov 2022, 17:28
TD-er wrote: 21 Nov 2022, 17:23 I did format the code a bit more so it is readable with consistent indents:
i already did... ;)
viewtopic.php?p=61170#p61170
bledad
#44 Post by bledad » 22 Nov 2022, 10:44
it's my working 8 relay esp8266
be able to modify the action of each relay , ( on , off , on auto with schedule )
#45 Post by TD-er » 22 Nov 2022, 10:56
So just to be clear, you only want to switch each relais on or off given some time interval?
For example:
- relais 1
- GPIO 13, inverted logic: "0" is "on"
- When: %syssec_d% > 28800 and %syssec_d% < 72000
There also seems to be some variable # 11, which does seem to indicate the following:
- [Var#11]=0 //always off
- [Var#11]=1 //always on
- [Var#11]=2 //Timer mode
That's what I am reading in this rules code:
    gpio,13,0
    gpio,13,0
    gpio,13,1
Is that what you really intend to do?
bledad
#46 Post by bledad » 22 Nov 2022, 11:43
For example:
- relais 1
- forced on without %syssec_d% > 28800 and %syssec_d% < 72000
- forced off without %syssec_d% > 28800 and %syssec_d% < 72000
and for
- relais 3
- same thing
- add stop and start every 15 min. when %syssec_d% > 36000 and %syssec_d% < 68400
chromo23
#47 Post by chromo23 » 22 Nov 2022, 11:45
and to clarify
should for better understanding have this annotation
  else         //always off if var#11 anything else than 2 or 1 or %syssec_d% is outside the defined area
chromo23
#48 Post by chromo23 » 22 Nov 2022, 11:46
For example:
- relais 1
and for
- relais 3
- same thing
then the code i send you should work.
can you test it and report?
Edit: here the whole thing with the latest change:
On System#Boot Do
  Let,1,0
  Let,2,0
On Rules#Timer=2 Do
  // relais
On Rules#Timer=1 Do
  If [Var#1]=2
    GPIOToggle,14
  Elseif [Var#1]=0
    GPIO,14,1
  Endif
    gpio,13,0
    gpio,13,0
    gpio,13,1
	//relais 2 fontaine
    gpio,12,0
  elseif [Var#12]=1
    gpio,12,0
    gpio,12,1
    Let,1,2
    gpio,14,0
    Let,1,1
  Else
    Let,1,0
  Endif
	//relais 4
    gpio,16,0
  elseif [Var#14]=1
    gpio,16,0
  Else
    gpio,16,1
    gpio,4,0
  elseif [Var#15]=1
    gpio,4,0
  Else
   gpio,4,1
	//relais 6
    gpio,5,0
  elseif [Var#16]=1
    gpio,5,0
  Else
    gpio,5,1
	//relais 7
    gpio,3,0
  elseif [Var#17]=1
    gpio,3,0
  Else
    gpio,3,1
	//relais 8
    gpio,1,0
  elseif [Var#18]=1
    gpio,1,0
  Else
    gpio,1,1
chromo23
#49 Post by chromo23 » 22 Nov 2022, 12:23
You don´t even need
Just put the code from there to
On Rules#Timer=2 Do
And then it will check everything every 5 seconds...
On System#Boot Do
  Let,1,0
  Let,2,0
On Rules#Timer=1 Do
  If [Var#1]=2
    GPIOToggle,14
  Elseif [Var#1]=0
    GPIO,14,1
  Endif
On Rules#Timer=2 Do
  // relais
    gpio,13,0
    gpio,13,0
    gpio,13,1
	//relais 2 fontaine
    gpio,12,0
  elseif [Var#12]=1
    gpio,12,0
    gpio,12,1
    Let,1,2
    gpio,14,0
    Let,1,1
  Else
    Let,1,0
  Endif
	//relais 4
    gpio,16,0
  elseif [Var#14]=1
    gpio,16,0
  Else
    gpio,16,1
    gpio,4,0
  elseif [Var#15]=1
    gpio,4,0
  Else
   gpio,4,1
	//relais 6
    gpio,5,0
  elseif [Var#16]=1
    gpio,5,0
  Else
    gpio,5,1
	//relais 7
    gpio,3,0
  elseif [Var#17]=1
    gpio,3,0
  Else
    gpio,3,1
	//relais 8
    gpio,1,0
  elseif [Var#18]=1
    gpio,1,0
  Else
    gpio,1,1
#50 Post by TD-er » 22 Nov 2022, 12:56
Why do you need the 5 sec interval timer?
It needs to toggle some relais at 15 min interval.
Users browsing this forum: Anthropic Claude Bot [bot], OpenAI GPTBot [bot] and 16 guests
