Cheap 433Mhz 1/2/3 Gang Remote Control Glass Panel Smart Light Switch
Any chance, to get support for these cheap wall 433mhz switches?
here is the link for ebay: http://www.ebay.com/itm/281730112717
Re: Cheap 433Mhz 1/2/3 Gang Remote Control Glass Panel Smart Light Switch
Do you already have this device?
yes. i got it.
it uses small 433mhz remote... scan is here: on chip, there is HS1527 (08GH0)
Ok, make a debug log as explained here http://www.nemcon.nl/blog2/2015/07/cc
this is output:
20;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R41;
10;version;
20;01;VER=1.1;REV=41;BUILD=03;
this is key A:
20;12;Eurodomest;ID=022e5d;SWITCH=05;CMD=ALLON;
20;13;EV1527;ID=0dd1a2;SWITCH=04;CMD=ON;
this is key B:
20;14;Eurodomest;ID=022e5d;SWITCH=07;CMD=ALLOFF;
20;15;EV1527;ID=0dd1a2;SWITCH=01;CMD=ON;
this is key C:
20;17;EV1527;ID=0dd1a2;SWITCH=08;CMD=ON;
this is key D:
20;0E;Eurodomest;ID=022e5d;SWITCH=06;CMD=ALLON;
20;0F;EV1527;ID=0dd1a2;SWITCH=02;CMD=ON;
10;version;
this is key A:
this is key B:
this is key C:
this is key D:
and with debug on: hope it helps....
key A:
20;20;DEBUG;Pulses=44;Pulses(uSec)=1260,60,1170,60,1140,60,420,810,1140,90,420,810,420,810,390,810,1110,120,1080,150,360,840,1110,120,360,840,360,870,360,840,1080,150,360,840,360,870,1050,180,360,870,360,870,360,6990;
20;21;DEBUG;Pulses=50;Pulses(uSec)=1110,180,1050,180,330,900,1050,180,1020,180,1020,180,330,900,1020,210,330,900,330,900,330,900,1020,210,1020,210,300,900,1020,210,330,900,300,900,330,900,1020,210,300,900,300,900,1020,210,300,900,300,900,300,6990;
20;22;EV1527;ID=0dd1a2;SWITCH=04;CMD=ON;
key B:
20;29;DEBUG;Pulses=46;Pulses(uSec)=3420,780,1170,60,1140,90,1110,120,420,810,1080,150,390,810,390,840,390,810,1110,120,1110,120,390,840,1080,150,360,840,360,870,360,840,1080,150,360,870,360,870,360,870,360,870,1080,150,360,6990;
20;2A;DEBUG;Pulses=50;Pulses(uSec)=1110,180,1020,180,330,900,1020,210,1020,180,1020,210,300,900,1020,210,330,900,300,900,330,900,1020,210,1020,210,300,900,1020,210,300,900,300,900,300,900,1020,210,300,900,300,900,300,900,300,900,1020,210,300,6990;
20;2B;EV1527;ID=0dd1a2;SWITCH=01;CMD=ON;
key C:
20;52;DEBUG;Pulses=48;Pulses(uSec)=30,150,90,150,1170,90,1140,90,1140,90,420,810,1140,90,420,810,390,840,390,840,1110,120,1080,120,390,840,1110,150,360,840,360,840,360,870,1080,150,360,840,1050,150,360,870,360,870,330,870,330,6990;
20;53;DEBUG;Pulses=50;Pulses(uSec)=1110,180,1020,180,330,900,1050,180,1020,210,1020,210,330,900,1020,210,330,900,300,900,330,900,1020,210,1020,210,330,900,1020,210,330,900,300,900,300,900,1020,210,300,900,1020,210,300,900,300,900,300,900,300,6990;
20;54;EV1527;ID=0dd1a2;SWITCH=08;CMD=ON;
key D:
20;55;DEBUG;Pulses=44;Pulses(uSec)=1290,60,1140,60,1140,90,390,840,1110,120,390,810,390,840,360,840,1080,150,1080,150,390,840,1080,150,360,840,360,840,360,870,1080,150,360,840,360,870,360,870,1080,150,360,870,330,6990;
20;56;DEBUG;Pulses=50;Pulses(uSec)=1110,180,1050,180,330,900,1050,210,1020,180,1020,210,330,900,1020,210,300,900,330,900,300,900,1020,210,1020,210,330,900,1020,210,300,900,300,900,300,930,1020,210,300,900,300,900,300,900,1020,210,300,930,300,6990;
20;57;EV1527;ID=0dd1a2;SWITCH=02;CMD=ON;
key A:
key B:
key C:
key D:
Looking at your data it seems the only issue is that it recognizes your device as both Eurodomest and EV1527.
I think the EV1527 is correct as the controller chip is a 1527 model.
So the Eurodomest should not be reported.
I have send you an email with a test version.
flashed that FW, now it is working like this:
20;07;EV1527;ID=029d69;SWITCH=04;CMD=ON;
20;08;EV1527;ID=029d69;SWITCH=08;CMD=ON;
20;09;EV1527;ID=029d69;SWITCH=02;CMD=ON;
20;0A;EV1527;ID=029d69;SWITCH=01;CMD=ON;
so in domoticz I can manual add 4diff switches under switch type: button ON, and type: ARC? or what kind of brand to use?
thnx
thnx
RFLink automatically detects and tells Domoticz. There should be 4 devices under "settings/devices".
All you need to do is press the green arrow on the device list to add them to the switches tab.
ok, thank you.
but is there any chance, to enter it manualy? I got only 4 buttons, so I can let domoticz learn only 4codes, in 2gang switch i can also use not just push ON, push OFF but also SWITCH and there is no room in remote for that
i was trying every option in manual add switch, and didn't find anything to produce CHUANGO or EV175 code....
thank you
thank you
