Cheap 433Mhz 1/2/3 Gang Remote Control Glass Panel Smart Light Switch
Post here about devices that are not yet or not fully supported
grz3
#1 Post by grz3 » 03 May 2016, 17:07
Any chance, to get support for these cheap wall 433mhz switches?
here is the link for ebay: http://www.ebay.com/itm/281730112717
Stuntteam
Site Beheer
Re: Cheap 433Mhz 1/2/3 Gang Remote Control Glass Panel Smart Light Switch
#2 Post by Stuntteam » 04 May 2016, 08:33
Do you already have this device?
grz3
#3 Post by grz3 » 04 May 2016, 21:48
yes. i got it.
it uses small 433mhz remote... scan is here: on chip, there is HS1527 (08GH0)
Stuntteam
Site Beheer
#4 Post by Stuntteam » 05 May 2016, 10:45
Ok, make a debug log as explained here http://www.nemcon.nl/blog2/2015/07/cc
grz3
#5 Post by grz3 » 16 May 2016, 20:09
this is output:
20;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R41;
10;version;
20;01;VER=1.1;REV=41;BUILD=03;
this is key A:
20;12;Eurodomest;ID=022e5d;SWITCH=05;CMD=ALLON;
20;13;EV1527;ID=0dd1a2;SWITCH=04;CMD=ON;
this is key B:
20;14;Eurodomest;ID=022e5d;SWITCH=07;CMD=ALLOFF;
20;15;EV1527;ID=0dd1a2;SWITCH=01;CMD=ON;
this is key C:
20;17;EV1527;ID=0dd1a2;SWITCH=08;CMD=ON;
this is key D:
20;0E;Eurodomest;ID=022e5d;SWITCH=06;CMD=ALLON;
20;0F;EV1527;ID=0dd1a2;SWITCH=02;CMD=ON;
grz3
#6 Post by grz3 » 16 May 2016, 20:13
and with debug on: hope it helps....
key A:
20;20;DEBUG;Pulses=44;Pulses(uSec)=1260,60,1170,60,1140,60,420,810,1140,90,420,810,420,810,390,810,1110,120,1080,150,360,840,1110,120,360,840,360,870,360,840,1080,150,360,840,360,870,1050,180,360,870,360,870,360,6990;
20;21;DEBUG;Pulses=50;Pulses(uSec)=1110,180,1050,180,330,900,1050,180,1020,180,1020,180,330,900,1020,210,330,900,330,900,330,900,1020,210,1020,210,300,900,1020,210,330,900,300,900,330,900,1020,210,300,900,300,900,1020,210,300,900,300,900,300,6990;
20;22;EV1527;ID=0dd1a2;SWITCH=04;CMD=ON;
key B:
20;29;DEBUG;Pulses=46;Pulses(uSec)=3420,780,1170,60,1140,90,1110,120,420,810,1080,150,390,810,390,840,390,810,1110,120,1110,120,390,840,1080,150,360,840,360,870,360,840,1080,150,360,870,360,870,360,870,360,870,1080,150,360,6990;
20;2A;DEBUG;Pulses=50;Pulses(uSec)=1110,180,1020,180,330,900,1020,210,1020,180,1020,210,300,900,1020,210,330,900,300,900,330,900,1020,210,1020,210,300,900,1020,210,300,900,300,900,300,900,1020,210,300,900,300,900,300,900,300,900,1020,210,300,6990;
20;2B;EV1527;ID=0dd1a2;SWITCH=01;CMD=ON;
key C:
20;52;DEBUG;Pulses=48;Pulses(uSec)=30,150,90,150,1170,90,1140,90,1140,90,420,810,1140,90,420,810,390,840,390,840,1110,120,1080,120,390,840,1110,150,360,840,360,840,360,870,1080,150,360,840,1050,150,360,870,360,870,330,870,330,6990;
20;53;DEBUG;Pulses=50;Pulses(uSec)=1110,180,1020,180,330,900,1050,180,1020,210,1020,210,330,900,1020,210,330,900,300,900,330,900,1020,210,1020,210,330,900,1020,210,330,900,300,900,300,900,1020,210,300,900,1020,210,300,900,300,900,300,900,300,6990;
20;54;EV1527;ID=0dd1a2;SWITCH=08;CMD=ON;
key D:
20;55;DEBUG;Pulses=44;Pulses(uSec)=1290,60,1140,60,1140,90,390,840,1110,120,390,810,390,840,360,840,1080,150,1080,150,390,840,1080,150,360,840,360,840,360,870,1080,150,360,840,360,870,360,870,1080,150,360,870,330,6990;
20;56;DEBUG;Pulses=50;Pulses(uSec)=1110,180,1050,180,330,900,1050,210,1020,180,1020,210,330,900,1020,210,300,900,330,900,300,900,1020,210,1020,210,330,900,1020,210,300,900,300,900,300,930,1020,210,300,900,300,900,300,900,1020,210,300,930,300,6990;
20;57;EV1527;ID=0dd1a2;SWITCH=02;CMD=ON;
Stuntteam
Site Beheer
#7 Post by Stuntteam » 17 May 2016, 19:04
Looking at your data it seems the only issue is that it recognizes your device as both Eurodomest and EV1527.
I think the EV1527 is correct as the controller chip is a 1527 model.
So the Eurodomest should not be reported.
I have send you an email with a test version.
grz3
#8 Post by grz3 » 17 May 2016, 20:41
flashed that FW, now it is working like this:
20;07;EV1527;ID=029d69;SWITCH=04;CMD=ON;
20;08;EV1527;ID=029d69;SWITCH=08;CMD=ON;
20;09;EV1527;ID=029d69;SWITCH=02;CMD=ON;
20;0A;EV1527;ID=029d69;SWITCH=01;CMD=ON;
so in domoticz I can manual add 4diff switches under switch type: button ON, and type: ARC? or what kind of brand to use?
thnx
Stuntteam
Site Beheer
#9 Post by Stuntteam » 18 May 2016, 09:29
RFLink automatically detects and tells Domoticz. There should be 4 devices under "settings/devices".
All you need to do is press the green arrow on the device list to add them to the switches tab.
grz3
#10 Post by grz3 » 18 May 2016, 16:38
ok, thank you.
but is there any chance, to enter it manualy? I got only 4 buttons, so I can let domoticz learn only 4codes, in 2gang switch i can also use not just push ON, push OFF but also SWITCH and there is no room in remote for that :-)
i was trying every option in manual add switch, and didn't find anything to produce CHUANGO or EV175 code....
thank you
