"log": "",
"plugin": 9,
"pin": 4,
"mode": "input",
"state": 0
"log": "",
"plugin": 9,
"pin": 4,
"mode": "input",
"state": 0
The "status" command is (also) an ESPEasy core command and doesn't need a device/task to be set up, only connected (but that shouldn't be a problem
on ... do
on System#Boot do
Monitor,MCP,<MCPGPIO> // Need to fill in the pin(s) you would like to monitor
on mcp#1 do // Act on MCP pin #1
if %eventvalue1%=0
// pin state low
// pin state high
On System#Boot Do
MCPModeRange,17,32,1
MonitorRange,MCP,17,32
if %eventvalue1%=0
// pin state low
otherwise
// pin state high
SendToUDP,<destination-ip>,<port>,'%sysname%_mcp_1_state=%eventvalue1%'
// Or alternatively for all pins in a single rule:
on mcp do
SendToUDP,<destination-ip>,<port>,'%sysname%_mcp_%eventpar%_state=%eventvalue1%'
on mcp do
on mcp#26 do
on mcp* do
on mcp* do
If [mcp*#eventvalue1]=1 Do
SendToUDP,192.168.1.100,5555,'%sysname%_mcp_%eventpar%_state=0'
Endif
If [mcp*#eventvalue1]=0 Do
SendToUDP,192.168.1.100,5555,'%sysname%_mcp_%eventpar%_state=1'
Endif
Could be as simple as this: (eventvalueX must be wrapped with % signs)Smotek7 wrote: ↑10 Sep 2024, 15:37Code: Select all
on mcp* do If [mcp*#eventvalue1]=1 Do SendToUDP,192.168.1.100,5555,'%sysname%_mcp_%eventpar%_state=0' Endif If [mcp*#eventvalue1]=0 Do SendToUDP,192.168.1.100,5555,'%sysname%_mcp_%eventpar%_state=1' Endif endon
on mcp* do
SendToUDP,192.168.1.100,5555,'%sysname%_mcp_%eventpar%_state=!%eventvalue1%'
on mcp* do
let,1,!%eventvalue1%
SendToUDP,192.168.1.100,5555,'%sysname%_mcp_%eventpar%_state=%v1%'
on mcp* do
Let,1,!%eventvalue1%
gpio,1,=!%eventvalue1%
on mcp* do
TaskValueSet,1,1,%eventpar%
TaskValueSet,1,2,%v1%
TaskValueSetAndRun,1,1,%eventpar%*10+%v1%
2 things are probably mixed up here:
