on GPS#travelled do
let,1,[GPS#spd#d2.0]*3.6 // Store speed in km/h in variable #1
Publish,"%sysname%/GPS/Distanz Trigger/Speed", [int#1]
Publish,"%sysname%/GPS/Distanz Trigger/Longitude", [GPS#long]
Publish,"%sysname%/GPS/Distanz Trigger/Latitude", [GPS#lat]
You first store the speed in km/h in variable #1.
When accessing this via [var#1] you get it as a floating point value.
But since you try to format it anyway, you can also fetch it as an integer value. [int#1]
You can store values in as many variables as you like.
For example you can also compute the average speed, since the GPS does output a new value every second.
on GPS#travelled do
let,2,[var#1}+[var#2] // collect the sum of all speeds in var#2
let,3,[int#3]+1 // Count how many stored in the sum
On Rules#Timer=2 do
Publish,"%sysname%/GPS/Distanz Trigger/Speed", [GPS#spd#d2.0]
// Publish,"%sysname%/GPS/Distanz Trigger/Altitude", [GPS#alt#d0.0]
Publish,"%sysname%/GPS/Distanz Trigger/ODO", [GPS#dist#d0.0]
if [int#3] > 0
let,4,[var#2]/[int#3]
Publish,"%sysname%/GPS/Distanz Trigger/AvgSpd", [var#4#d2.0]
let,2,0
let,3,0
timerSet,2,120
The let command allows for all kinds of calculations.
In theory you could also do the computations in the publish command, but the calculations are then not always run as expected.
Using the let command it is way more predictable
