R108 issues
dzikus
R108 issues
#1 Post by dzikus » 12 Jul 2016, 10:13
I just make upgrade of one of my ESPEasy from R78 to R108 and I notice such issues:
1. If you enable "Admin Password" in Config, the 302 in http doesnt work, proof:
lapek:~ grzegorz$ curl -v 172.28.10.31
* Rebuilt URL to: 172.28.10.31/
*   Trying 172.28.10.31...
* Connected to 172.28.10.31 (172.28.10.31) port 80 (#0)
> GET / HTTP/1.1
> Host: 172.28.10.31
> User-Agent: curl/7.43.0
> Accept: */*
< HTTP/1.1 302
* Connection #0 to host 172.28.10.31 left intact
My browsers (I tested Chrome and Firefox) doesn't go to http://172.28.10.31/login like in R78.
The same happens if we add a slash at the end:
lapek:~ grzegorz$ curl -v 172.28.10.31/login/
> GET /login/ HTTP/1.1
> Host: 172.28.10.31
> Accept: */*
< HTTP/1.1 302
2. DHT22 doesn't work, I tested it with Arduino Leonardo and Adafruit <DHT_U.h> and it works, but not with ESPEasy. My config of DHT22 is on screenshots.
nightshark
Re: R108 issues
#2 Post by nightshark » 12 Jul 2016, 13:39
My dht22 works. I'm thinking it's because idx is zero. Assign a number.
dzikus
Re: R108 issues
#3 Post by dzikus » 12 Jul 2016, 22:20
nightshark wrote:My dht22 works. I'm thinking it's because idx is zero. Assign a number.
This is solution, after setting idx dht22 starts to work.
dzikus
Re: R108 issues
#4 Post by dzikus » 13 Jul 2016, 09:55
This is strange but it also repair 302 in http:
[grzegorz@x ~]$ curl -v 172.28.10.31
> GET / HTTP/1.1
> Host: 172.28.10.31
> User-Agent: curl/7.47.1
> Accept: */*
< HTTP/1.1 302
< Location: /login
Dylantje
Re: R108 issues
#5 Post by Dylantje » 14 Jul 2016, 08:32
mmm
I do have problems to..
Is did flash 108 over my 78 version...[ with the flashtool ]
After that my ESP became in a restart loop.
Flash back to 78 loop to.
Strange thing, i my mind is a flash a clean start.??
Only the ESP did remember al my old device[ dht,,1 wire etc ]
How can i get a clean flash?
Or a reset methode?
xxx
ps: my other ESP with 78 works perfect!!!
romix
Re: R108 issues
#6 Post by romix » 17 Jul 2016, 14:14
Connect RX and TX, then power up. Release after a few seconds. This will wipe the Flash settings.
tozett
Re: R108 issues. WIPE FLASH perfectly and total
#7 Post by tozett » 17 Jul 2016, 17:37
since i follow the version/rom upgrades, i always had this similar issues with error-reboots after upgrade.
mostly i had assumed the flash-information left over caused this.
peter scargill reported similar and had a total solution.
maybe one has to try this, but it wipes all conifg. maybe one makes a config backup-before...(it this holds the new version clean ??)
http://tech.scargill.net/esp-sdk-and-rboot-woes/
Users browsing this forum: Semrush [Bot] and 14 guests
