[SOLVED] Automatic GPIO High, after few seconds
garvarma
#1 Post by garvarma » 26 Jul 2016, 08:57
Continue with my test of ESPEasy and mqtt, i want to publish by openhab to mqtt to switch on GPIO2 on device with ESPEasy.
After configuring and touch many configurations in ESP Easy, i decided to reset device, to begin from 0 (i did it by rule like this):
On System#Boot do
  publish /nodemcu/cmd reset
  reset
and worked because i tourned to R108.
After rebooting device, i update to R113, and then I configure, IP device, mqtt server, and devices (rules are all 0):
In hardware menu, i have PIN 2 like default.
Well, when i switch on device, led in GPIO Switch on. and then by http i turn it off, becaue i want begin with my test.
I dunno why, after a few seconds, after turning off led by http, himself turn it on automatic, there are logs:
EVENT: Clock#Time=Tue,08:36
SW   : GPIO 2 Set to 0                ====> set by http://IP_device/control?cmd=GPIO,2,0
SW   : State 0
EVENT: subir#Switch=0.00
SW   : State 0
EVENT: bajar#Switch2=0.00
HTTP : Delay 999 ms
MQTT : Topic: /nodemcu/subir/Switch
MQTT : Payload: 0
MQTT : Topic: /nodemcu/bajar/Switch2
MQTT : Payload: 0
WD   : Uptime 10 ConnectFailures 11 FreeMem 29416
WD   : Uptime 10 ConnectFailures 10 FreeMem 29648
MQTT : Connection lost
MQTT : Connected to broker
Subscribed to: /nodemcu/#
MQTT : Payload: 1
MQTT : Payload: 1
MQTT : Topic: /nodemcu/gpio/2
MQTT : Payload: 1
SW   : GPIO 2 Set to 1
SW   : State 1
EVENT: subir#Switch=1.00
SW   : State 1
EVENT: bajar#Switch2=1.00
HTTP : Delay 999 ms
MQTT : Payload: 1
MQTT : Payload: 1
EVENT: Clock#Time=Tue,08:37
WD   : Uptime 11 ConnectFailures 12 FreeMem 29400
WD   : Uptime 11 ConnectFailures 11 FreeMem 29632
I dunno why, each time when device lost connection to broker and connect again, always switch to 1 GPIO 2.
maybe is a bug on R113? Why this occurs?
thanks
tozett
Re: Automatic GPIO High, after few seconds
#2 Post by tozett » 26 Jul 2016, 09:05
i have no direct answer to your question,
but i noticed in your rules, you do a reset twice.
1 x with publish to cmd and
1x with reset as a rules-cmd..
may only 1 reset is enough?
maybe the gpio goes 1, because there is something wired to the pin?
or a long wire on this pin?
maybe you have an unstable board?
for all software/firmware issues or explanations, there must be comments be a coder. (not me :shock: )
garvarma
#3 Post by garvarma » 27 Jul 2016, 08:47
Hi tozett,
Yes i know that in rules the reset command was twice. The reason is because in wiki says that by mqtt and by http is posible to send comands, so first of all I tried by http, but doesn't work..., then i tried by mqtt directly, but also doesn't work...
So at the end i deciced to do it by rules, and twice because if by publish to cmd mqtt-rule doesn't work, then do it by directly command rule.
Well with this option worked, beucase i think that by publish to cmd mqtt didn't worked.
The only thing that was wired is a led. to show if GPIO is 1 or 0. But well, at the end i found which was the problem, but i don't understand why. The problem was other esp that i have plug, but with other name_device, and other devices name, that each time (publish something) and led on esp1 switched on, every time that i switched off.
tozett
#4 Post by tozett » 28 Jul 2016, 11:21
may check to different device-numbers on main-page of espeasy.
also may not use "global-sync" ?
if case is solved, may change topic on first post to " SOLVED ..."? ;)
Users browsing this forum: Bing [Bot] and 11 guests
