Steps taken to verify OTA upgrade from R78 to R108 on a black ESP-01 module:
1) Took a brand new ESP-01 black with the original ai-thinker firmware still loaded.
2) Used the flash.cmd tool to upload ESPEasy_R78_1024.bin using the serial port.
3) Configured wifi ssid and key and IP address through serial port, save, reboot, connection is ok.
4) Verified webgui access, ok
5) Using the ESP webgui to upload ESPEasy_R108_1024.bin file
6) Verified webgui, runs fine using R108.
Serial log during this upgrade process:
INIT : Booting Build nr:78
IP : Static IP :192.168.0.122
WIFI : Connecting... 1
WIFI : Connected!
INIT : I2C
INIT : Boot OK
INIT : Normal boot
WD : Uptime 0 ConnectFailures 0 FreeMem 26552
WD : Uptime 1 ConnectFailures 0 FreeMem 26520
WD : Uptime 1 ConnectFailures 0 FreeMem 26456
WD : Uptime 2 ConnectFailures 0 FreeMem 26456
Update: ESPEasy_R108_1024.bin
sleep disable
Update Success: 406960
Rebooting...
ets Jan 8 2013,rst cause:2, boot mode:(3,7)
load 0x4010f000, len 1264, room 16
tail 0
chksum 0x42
csum 0x42
@cp:0
ld
ªU
Build changed!
Fix status LED Pin
Fix taskindex
FLASH: Settings saved
Fix extratasksettings
INIT : Booting Build nr:108
WIFI : Connected!
INIT : I2C
INIT : Boot OK
INIT : Cold Boot
WD : Uptime 0 ConnectFailures 0 FreeMem 27656
