I am trying to compile the sourcode with the Arduino IDE. I am keeping exactly to these instructions:
https://www.letscontrolit.com/wiki/inde ... are_Upload
Unfortunately I always get these error messages:
Arduino: 1.6.12 (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, 115200, 4M (1M SPIFFS)"
Command:522: error: variable or field 'printDirectory' declared void
void printDirectory(File dir, int numTabs) {
Command:522: error: 'File' was not declared in this scope
Command:522: error: expected primary-expression before 'int'
Networking:394: error: variable or field 'SSDP_schema' declared void
void SSDP_schema(WiFiClient client) {
Networking:394: error: 'WiFiClient' was not declared in this scope
_N001_Email:110: error: 'WiFiClient' was not declared in this scope
boolean NPlugin_001_MTA(WiFiClient client, String aStr, String aWaitForPattern)
_N001_Email:110: error: expected primary-expression before 'aStr'
_N001_Email:110: error: expected primary-expression before 'aWaitForPattern'
_N001_Email:110: error: expression list treated as compound expression in initializer [-fpermissive]
E:\Program Files\Arduino\ESPeasy_portable\ESPEasy_v2.0.0-dev8\Source\ESPeasy\Command.ino: In function 'bool safeReadStringUntil(Stream&, String&, char, int, int)':
Command:29: error: 'LOG_LEVEL_ERROR' was not declared in this scope
addLog(LOG_LEVEL_ERROR, F("Not enough bufferspace to read all input data!"));
Command:37: error: 'LOG_LEVEL_ERROR' was not declared in this scope
addLog(LOG_LEVEL_ERROR, F("Timeout while reading input data!"));
E:\Program Files\Arduino\ESPeasy_portable\ESPEasy_v2.0.0-dev8\Source\ESPeasy\Command.ino: In function 'void ExecuteCommand(byte, const char*)':
Command:89: error: 'RTC' was not declared in this scope
RTC.factoryResetCounter = 0;
Command:106: error: 'Settings' was not declared in this scope
if (Settings.NotificationEnabled[Par1 - 1] && Settings.Notification[Par1 - 1] != 0)
Command:109: error: aggregate 'EventStruct TempEvent' has incomplete type and cannot be defined
struct EventStruct TempEvent;
Command:111: error: 'NPlugin_id' was not declared in this scope
if (NPlugin_id[NotificationProtocolIndex] != 0)
Command:112: error: 'NPlugin_ptr' was not declared in this scope
NPlugin_ptr[NotificationProtocolIndex](NPLUGIN_NOTIFY, &TempEvent, message);
Command:112: error: 'NPLUGIN_NOTIFY' was not declared in this scope
Command:120: error: 'RTC' was not declared in this scope
RTC.flashDayCounter = 0;
Command:137: error: 'File' was not declared in this scope
File root = SD.open("/");
Command:137: error: expected ';' before 'root'
Command:138: error: 'root' was not declared in this scope
root.rewindDirectory();
Command:139: error: 'printDirectory' was not declared in this scope
printDirectory(root, 0);
Command:150: error: 'SD' was not declared in this scope
SD.remove((char*)fname.c_str());
Command:155: error: 'lowestRAM' was not declared in this scope
Serial.print(lowestRAM);
Command:157: error: 'lowestRAMid' was not declared in this scope
Serial.println(lowestRAMid);
Command:170: error: 'loopCounterLast' was not declared in this scope
Serial.print(100 - (100 * loopCounterLast / loopCounterMax));
Command:170: error: 'loopCounterMax' was not declared in this scope
Command:188: error: 'SecuritySettings' was not declared in this scope
Serial.println(sizeof(SecuritySettings));
Command:190: error: 'Settings' was not declared in this scope
Serial.println(sizeof(Settings));
Command:192: error: 'ExtraTaskSettings' was not declared in this scope
Serial.println(sizeof(ExtraTaskSettings));
Command:194: error: 'Device' was not declared in this scope
Serial.println(sizeof(Device));
Command:206: error: 'Wire' was not declared in this scope
Wire.beginTransmission(Par1); // address
Command:215: error: 'Wire' was not declared in this scope
Command:231: error: 'Settings' was not declared in this scope
Settings.Build = Par1;
Command:238: error: 'Settings' was not declared in this scope
Settings.deepSleep = 0;
Command:248: error: 'Wire' was not declared in this scope
Wire.beginTransmission(address);
Command:281: error: 'UserVar' was not declared in this scope
UserVar[(VARS_PER_TASK * (Par1 - 1)) + Par2 - 1] = result;
Command:281: error: 'VARS_PER_TASK' was not declared in this scope
Command:293: error: 'RULES_TIMER_MAX' was not declared in this scope
if (Par1>=0 && Par1<RULES_TIMER_MAX)
Command:298: error: 'RulesTimer' was not declared in this scope
RulesTimer[Par1 - 1] = millis() + (1000 * Par2);
Command:301: error: 'RulesTimer' was not declared in this scope
RulesTimer[Par1 - 1] = 0L;
Command:315: error: 'Settings' was not declared in this scope
Settings.UseRules = true;
Command:317: error: 'Settings' was not declared in this scope
Settings.UseRules = false;
Command:326: error: 'Settings' was not declared in this scope
if (Settings.UseRules)
Command:353: error: 'MQTTclient' was not declared in this scope
MQTTclient.publish(topic.c_str(), value.c_str(), Settings.MQTTRetainFlag);
Command:353: error: 'Settings' was not declared in this scope
Command:367: error: 'IPAddress' was not declared in this scope
IPAddress UDP_IP(ipaddress[0], ipaddress[1], ipaddress[2], ipaddress[3]);
Command:367: error: expected ';' before 'UDP_IP'
Command:368: error: 'portUDP' was not declared in this scope
portUDP.beginPacket(UDP_IP, port.toInt());
Command:368: error: 'UDP_IP' was not declared in this scope
Command:381: error: 'WiFiClient' was not declared in this scope
WiFiClient client;
Command:381: error: expected ';' before 'client'
WiFiClient client;
Command:382: error: 'client' was not declared in this scope
if (client.connect(host.c_str(), port.toInt()))
Command:399: error: 'LOG_LEVEL_DEBUG' was not declared in this scope
addLog(LOG_LEVEL_DEBUG, line);
Command:414: error: 'SecuritySettings' was not declared in this scope
strcpy(SecuritySettings.WifiSSID, Line + 9);
Command:420: error: 'SecuritySettings' was not declared in this scope
strcpy(SecuritySettings.WifiKey, Line + 8);
Command:458: error: 'WiFi' was not declared in this scope
WiFi.persistent(true); // use SDK storage of SSID/WPA parameters
Command:484: error: 'Settings' was not declared in this scope
Settings.SerialLogLevel = Par1;
Command:491: error: 'Settings' was not declared in this scope
if (!str2ip(TmpStr1, Settings.IP))
Command:502: error: 'IPAddress' was not declared in this scope
IPAddress ip = WiFi.localIP();
Command:502: error: expected ';' before 'ip'
Command:503: error: 'ip' was not declared in this scope
sprintf_P(str, PSTR("%u.%u.%u.%u"), ip[0], ip[1], ip[2], ip[3]);
Command:505: error: 'BUILD' was not declared in this scope
Serial.print(F(" Build : ")); Serial.println((int)BUILD);
Command:506: error: 'Settings' was not declared in this scope
Serial.print(F(" Unit : ")); Serial.println((int)Settings.Unit);
Command:507: error: 'SecuritySettings' was not declared in this scope
Serial.print(F(" WifiSSID : ")); Serial.println(SecuritySettings.WifiSSID);
E:\Program Files\Arduino\ESPeasy_portable\ESPEasy_v2.0.0-dev8\Source\ESPeasy\Command.ino: At global scope:
In file included from e:\program files\arduino\espeasy_portable\arduino-1.6.12p230\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\typeinfo:34:0,
from e:\program files\arduino\espeasy_portable\arduino-1.6.12p230\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\functional:53,
from E:\Program Files\Arduino\ESPeasy_portable\arduino-1.6.12P230\portable\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/ESP8266WiFiGeneric.h:27,
from E:\Program Files\Arduino\ESPeasy_portable\arduino-1.6.12P230\portable\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/ESP8266WiFiSTA.h:28,
from E:\Program Files\Arduino\ESPeasy_portable\arduino-1.6.12P230\portable\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/ESP8266WiFi.h:34,
from E:\Program Files\Arduino\ESPeasy_portable\ESPEasy_v2.0.0-dev8\Source\ESPeasy\ESPEasy.ino:273:
e:\program files\arduino\espeasy_portable\arduino-1.6.12p230\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\exception:35:37: error: expected declaration before end of line
#pragma GCC visibility push(default)
Multiple libraries were found for "Servo.h"
Used: E:\Program Files\Arduino\ESPeasy_portable\arduino-1.6.12P230\portable\packages\esp8266\hardware\esp8266\2.3.0\libraries\Servo
Not used: E:\Program Files\Arduino\ESPeasy_portable\arduino-1.6.12P230\libraries\Servo
Multiple libraries were found for "SD.h"
Used: E:\Program Files\Arduino\ESPeasy_portable\arduino-1.6.12P230\portable\packages\esp8266\hardware\esp8266\2.3.0\libraries\SD
Not used: E:\Program Files\Arduino\ESPeasy_portable\arduino-1.6.12P230\libraries\SD
exit status 1
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
Can anyone help please?
