IF statement on %eventvalue%
Posted: 23 Oct 2017, 12:50
by rayE
V2.0
I set up a rule as follows.
on configFlowSensor do
if [%eventvalue%] = 1
// Do something like set a GPIO output
I send the following HTTP request.
http://<your esp ip>/control?cmd=event,configFlowSenor=1
With the IF statement i get no response, without the IF statement it will set the digital output. The IF statement seems to ignore the value in %eventvalue% although it does trigger the rule.
Any pointers?
TIA
Ray
Re: IF statement on %eventvalue%
Posted: 23 Oct 2017, 14:39
by grovkillen
As seen in the wiki here:
https://www.letscontrolit.com/wiki/inde ... _Reference you cannot pass values with the event command.
To do so I suggest you try the TaskValueSet together with a dummy device (if you insist on using HTTP). If you use MQTT you could resolve the matter by using the MQTT import or use the TaskValueSet via cmd.
Posted: 23 Oct 2017, 15:15
by vader
What about the rule
if [configFlowSensor#ValueOfDevice] = 1
@grovkillen: You wrote "use the TaskValueSet via cmd". TaskValueSet is declared in the Wiki as rule command only, not for external usage!
Posted: 23 Oct 2017, 16:16
by grovkillen
vader wrote: ↑23 Oct 2017, 15:15
Aaah!! You're right. Sorry, wrote it on my phone and didn't think straight
Posted: 23 Oct 2017, 18:23
by toffel969
grovkillen wrote: ↑23 Oct 2017, 16:16
It is possible with TaskValueSet
You sent event value and write it into a dummy using taskvalueset within the event. Then you can check the dummys value within rules.
Posted: 23 Oct 2017, 18:30
by toffel969
You still start by sending http command with event value:
On the receiving ESP you create a Dummy device, lets say as device 1 in the device Tab. You name the value , for example memory
On configFlowSensor do
TaskValueSet 1,%eventvalue%
if [Dummy#memory]=1
// Do something
That should work!
Posted: 23 Oct 2017, 19:20
by vader
Not working. Messed the rules! BTW: TaskValueSet need 3 parameter...
Posted: 23 Oct 2017, 19:28
by toffel969
vader wrote: ↑23 Oct 2017, 19:20
You are right about the TaskValueSet needing 3 parameters. But then there is no reason y th shouldn't work
Posted: 23 Oct 2017, 19:44
by vader
I've tested it and does not work for me. I mean, you can not transmit values to an event. The parser seems to ignore more than 1 value after "event". It is only interested in the event name....
The messed rules seem to be an issue of core 2.4.0....
Posted: 23 Oct 2017, 19:58
by toffel969
I just tested this on one of my nodes running R142
it definitly works the way I described
Posted: 23 Oct 2017, 19:59
by toffel969
vader wrote: ↑23 Oct 2017, 19:44
You can send values, check the wiki
https://www.letscontrolit.com/wiki/inde ... _Variables
Posted: 23 Oct 2017, 20:10
by vader
Ok, now I got it. The "=" after event name was wrong (I had ",")...
Posted: 23 Oct 2017, 23:16
by danmero
on testevent do
TaskValueSet 5,4,%eventvalue%
http://x.x.x.x/control?cmd=event,testevent=3
This works on 2.0.0.x
Posted: 24 Oct 2017, 02:53
by rayE
Thanks guy's, this works a treat
Posted: 24 Oct 2017, 07:54
by grovkillen
toffel969 wrote: ↑23 Oct 2017, 19:59
I have now moved this section to its correct section
https://www.letscontrolit.com/wiki/inde ... alue.25.29
I hope more people will use this awesome technique (I sure hadn't seen it before you pointed it out).
Posted: 20 Nov 2017, 15:20
by danmero
I use this rule set to pass GPIO # as event argument.
on sniff#a do
event event1=%eventvalue%
on event1 do
pcfpulse %eventvalue%,0,200
Regards,
Posted: 20 Nov 2017, 16:32
by grovkillen
danmero wrote: ↑20 Nov 2017, 15:20
on sniff#a do
on event1 do
Regards,
Clever, will try to add this to the wiki as well.
