IF statement on %eventvalue%
rayE
#1 Post by rayE » 23 Oct 2017, 12:50
V2.0
I set up a rule as follows.
on configFlowSensor do
if [%eventvalue%] = 1
// Do something like set a GPIO output
I send the following HTTP request.
http://<your esp ip>/control?cmd=event,configFlowSenor=1
With the IF statement i get no response, without the IF statement it will set the digital output. The IF statement seems to ignore the value in %eventvalue% although it does trigger the rule.
Any pointers?
TIA
Ray
Re: IF statement on %eventvalue%
#2 Post by grovkillen » 23 Oct 2017, 14:39
As seen in the wiki here: https://www.letscontrolit.com/wiki/inde ... _Reference you cannot pass values with the event command.
To do so I suggest you try the TaskValueSet together with a dummy device (if you insist on using HTTP). If you use MQTT you could resolve the matter by using the MQTT import or use the TaskValueSet via cmd.
vader
#3 Post by vader » 23 Oct 2017, 15:15
What about the rule
if [configFlowSensor#ValueOfDevice] = 1
@grovkillen: You wrote "use the TaskValueSet via cmd". TaskValueSet is declared in the Wiki as rule command only, not for external usage!
#4 Post by grovkillen » 23 Oct 2017, 16:16
vader wrote: 23 Oct 2017, 15:15 @grovkillen: You wrote "use the TaskValueSet via cmd". TaskValueSet is declared in the Wiki as rule command only, not for external usage!
Aaah!! You're right. Sorry, wrote it on my phone and didn't think straight :oops:
toffel969
#5 Post by toffel969 » 23 Oct 2017, 18:23
grovkillen wrote: 23 Oct 2017, 16:16
It is possible with TaskValueSet
You sent event value and write it into a dummy using taskvalueset within the event. Then you can check the dummys value within rules.
toffel969
#6 Post by toffel969 » 23 Oct 2017, 18:30
You still start by sending http command with event value:
On the receiving ESP you create a Dummy device, lets say as device 1 in the device Tab. You name the value , for example memory
On configFlowSensor do
TaskValueSet 1,%eventvalue%
if [Dummy#memory]=1
// Do something
That should work!
vader
#7 Post by vader » 23 Oct 2017, 19:20
Not working. Messed the rules! BTW: TaskValueSet need 3 parameter...
toffel969
#8 Post by toffel969 » 23 Oct 2017, 19:28
vader wrote: 23 Oct 2017, 19:20 Not working. Messed the rules! BTW: TaskValueSet need 3 parameter...
You are right about the TaskValueSet needing 3 parameters. But then there is no reason y th shouldn't work
vader
#9 Post by vader » 23 Oct 2017, 19:44
I've tested it and does not work for me. I mean, you can not transmit values to an event. The parser seems to ignore more than 1 value after "event". It is only interested in the event name.... :D
The messed rules seem to be an issue of core 2.4.0.... :?
toffel969
#10 Post by toffel969 » 23 Oct 2017, 19:58
I just tested this on one of my nodes running R142
it definitly works the way I described
toffel969
#11 Post by toffel969 » 23 Oct 2017, 19:59
vader wrote: 23 Oct 2017, 19:44 I've tested it and does not work for me. I mean, you can not transmit values to an event. The parser seems to ignore more than 1 value after "event". It is only interested in the event name.... :D
You can send values, check the wiki
https://www.letscontrolit.com/wiki/inde ... _Variables
vader
#12 Post by vader » 23 Oct 2017, 20:10
Ok, now I got it. The "=" after event name was wrong (I had ",")... :oops:
danmero
#13 Post by danmero » 23 Oct 2017, 23:16
on testevent do
  TaskValueSet 5,4,%eventvalue%
http://x.x.x.x/control?cmd=event,testevent=3
This works on 2.0.0.x
rayE
#14 Post by rayE » 24 Oct 2017, 02:53
Thanks guy's, this works a treat :-)
#15 Post by grovkillen » 24 Oct 2017, 07:54
toffel969 wrote: 23 Oct 2017, 19:59
I have now moved this section to its correct section 8-)
https://www.letscontrolit.com/wiki/inde ... alue.25.29
I hope more people will use this awesome technique (I sure hadn't seen it before you pointed it out).
danmero
#16 Post by danmero » 20 Nov 2017, 15:20
I use this rule set to pass GPIO # as event argument.
on sniff#a do
  event event1=%eventvalue%
on event1 do
  pcfpulse %eventvalue%,0,200
Regards,
#17 Post by grovkillen » 20 Nov 2017, 16:32
danmero wrote: 20 Nov 2017, 15:20 I use this rule set to pass GPIO # as event argument.
on sniff#a do
on event1 do
Regards,
Clever, will try to add this to the wiki as well.
Users browsing this forum: Google [Bot] and 22 guests
