IF statement on %eventvalue%
V2.0
I set up a rule as follows.
on configFlowSensor do
if [%eventvalue%] = 1
// Do something like set a GPIO output
I send the following HTTP request.
http://<your esp ip>/control?cmd=event,configFlowSenor=1
With the IF statement i get no response, without the IF statement it will set the digital output. The IF statement seems to ignore the value in %eventvalue% although it does trigger the rule.
Any pointers?
TIA
Ray
V2.0
Any pointers?
TIA
Ray
Re: IF statement on %eventvalue%
As seen in the wiki here: https://www.letscontrolit.com/wiki/inde ... _Reference you cannot pass values with the event command.
To do so I suggest you try the TaskValueSet together with a dummy device (if you insist on using HTTP). If you use MQTT you could resolve the matter by using the MQTT import or use the TaskValueSet via cmd.
What about the rule
if [configFlowSensor#ValueOfDevice] = 1
@grovkillen: You wrote "use the TaskValueSet via cmd". TaskValueSet is declared in the Wiki as rule command only, not for external usage!
Aaah!! You're right. Sorry, wrote it on my phone and didn't think straight
It is possible with TaskValueSetgrovkillen wrote: ↑23 Oct 2017, 16:16Aaah!! You're right. Sorry, wrote it on my phone and didn't think straight![]()
You sent event value and write it into a dummy using taskvalueset within the event. Then you can check the dummys value within rules.
You still start by sending http command with event value:
On the receiving ESP you create a Dummy device, lets say as device 1 in the device Tab. You name the value , for example memory
That should work!
On configFlowSensor do
TaskValueSet 1,%eventvalue%
if [Dummy#memory]=1
// Do something
That should work!
Not working. Messed the rules! BTW: TaskValueSet need 3 parameter...
You are right about the TaskValueSet needing 3 parameters. But then there is no reason y th shouldn't work
I've tested it and does not work for me. I mean, you can not transmit values to an event. The parser seems to ignore more than 1 value after "event". It is only interested in the event name....
The messed rules seem to be an issue of core 2.4.0....
I just tested this on one of my nodes running R142
it definitly works the way I described
Ok, now I got it. The "=" after event name was wrong (I had ",")...
on testevent do
TaskValueSet 5,4,%eventvalue%
http://x.x.x.x/control?cmd=event,testevent=3
Thanks guy's, this works a treat
I have now moved this section to its correct sectiontoffel969 wrote: ↑23 Oct 2017, 19:59You can send values, check the wiki
https://www.letscontrolit.com/wiki/inde ... _Variables
https://www.letscontrolit.com/wiki/inde ... alue.25.29
I hope more people will use this awesome technique (I sure hadn't seen it before you pointed it out).
I use this rule set to pass GPIO # as event argument.
Regards,
on sniff#a do
event event1=%eventvalue%
on event1 do
pcfpulse %eventvalue%,0,200
Clever, will try to add this to the wiki as well.danmero wrote: ↑20 Nov 2017, 15:20 I use this rule set to pass GPIO # as event argument.Regards,Code: Select all
on sniff#a do event event1=%eventvalue% endon on event1 do pcfpulse %eventvalue%,0,200 endon
Users browsing this forum: Amazon [Bot] and 20 guests
