Wemos D1
Deennoo
Wemos D1
#1 Post by Deennoo » 07 Dec 2015, 21:41
Is a chance to run ESPEasy out of the box with this nodemcu "clone"
http://www.wemos.cc/wiki/doku.php?id=en:start
costo
Re: Wemos D1
#2 Post by costo » 07 Dec 2015, 22:51
The website says it can be programmed with the ESP-Arduino IDE, so you can flash ESPEasy on it.
fluppie
Re: Wemos D1
#3 Post by fluppie » 08 Dec 2015, 00:07
I have 2x Wemos D1 and 1x Wemos D1 Mini and also the end-of-life Wemos Lolin. All running fine :-).
Deennoo
Re: Wemos D1
#4 Post by Deennoo » 08 Dec 2015, 20:32
Mine are on on toll aéroport, Christmas time, toll are long
Just read that those are compatible with nodemcu code since 03 Décembre 2015
costo
Re: Wemos D1
#5 Post by costo » 08 Dec 2015, 21:17
Deennoo wrote:Mine are on on toll aéroport, Christmas time, toll are long
When you flash ESPEasy on this thing the NodeMCU firmware will be overwritten/erased so compatibility is not important I think.
Deennoo
Re: Wemos D1
#6 Post by Deennoo » 09 Dec 2015, 10:02
ok thanks, wainting to get it !
fluppie
Re: Wemos D1
#7 Post by fluppie » 09 Dec 2015, 10:08
As I use the Arduino environment (also the new 2.0 release on 1.6.5), I can confirm this works perfectly. Also it auto sets program mode, very easy :-). You just hit upload, no need to reset and pull up/down some GPIO's.
Deennoo
Re: Wemos D1
#8 Post by Deennoo » 29 Dec 2015, 22:09
Recieve today 5 x Wemos D1 Mini + dht shield
After solding pin, and loading ESPEasy b 58 on It, that run fast ! and looks stable, lets see the futur.
On mini i had to put d3 to gnd to enter on uploading mode.
Miki
Re: Wemos D1
#9 Post by Miki » 30 Dec 2015, 00:51
DHT11 or DHT22?
Over which GPIO Pin the DHT is connected? Can you post a screen from ur Device Config?
Thx
doxikus
Re: Wemos D1
#10 Post by doxikus » 30 Dec 2015, 14:48
Hi, I can confirm D! by Wemos works fine, have latest version on and works pretty well, btw I have ordered few of these breadboards so if you need something for quick prototyping
http://www.aliexpress.com/item/Free-shi ... 19368.html
