Hi, where can I find the password for Web login?
Or where can I adjust that?
In the esp easy sketch I could not find a config for it.
I flashed the R48 and configures the ESP-01. After a second reboot the Login Windows appeared.
Greetz Miki
Login Webinterface
Re: Login Webinterface
If you are talking about the Access-Point webgui on 192.168.4.1 this has a default password, which is defined in the beginning of the main program:
#define DEFAULT_AP_KEY "configesp"
If you leave it empty, you will need no password.
And if you are talking about admin password for configuration, it is being set in the Config tab and I have not seen ability to prepopulate it via content of INO.
But if you are getting a fully blown Windows login form (as a popup, not HTML form with place to enter password) when entering IP of the ESP, that means, something else is using this IP.
Michal 'Kotek', greetings from Poland. Zapraszam na mój blog o automatyce domowej po polsku: http://www.ukotka.com.
So this password is being set as Admin Password on Config tab. It must have survived your previous experiments, so you need to use a clean flash procedure mentioned here: http://www.esp8266.nu/forum/viewtopic.p ... =466#p2412
Just try 'reset' command using serial port. Should be sufficient to clear the config.
Thank You mkotek,
that worked for me.
that worked for me.
