GPIO "Unknown or restricted command!" in ESPEasy_mega-20180524
cowboytronic
#1 Post by cowboytronic » 27 May 2018, 23:29
Hi all,
Did something change in ESPEasy_mega-20180524?
I'm using a GeekCreit ESP-12F DevKit v2, and when I update from ESPEasy_mega-20180522 to ESPEasy_mega-20180524, suddenly the GPIO command doesn't work over HTTP any more.
using version ESPEasy_mega-20180522
$ curl http://192.168.1.203/control?cmd=GPIO,2,1
"log": "GPIO 2 Set to 1",
"plugin": 1,
"pin": 2,
"mode": "output",
"state": 1
using version ESPEasy_mega-20180524
$ curl http://192.168.1.203/control?cmd=GPIO,2,0
The change log indicates some changes went in for a GPIO expander, but nothing for the basic GPIO command.
Am I missing something?
Re: GPIO "Unknown or restricted command!" in ESPEasy_mega-20180524
#2 Post by TD-er » 28 May 2018, 22:55
This is indeed a bug.
There are now 2 plugins that claim to handle GPIO as command.
P001_Switch has the GPIO command and P022_PCA9685 has the GPIO command.
I will create an issue for it and it should be fixed by either changing the command for P022, or allowing to use the same commands on multiple tasks.
But I guess that last option will need a lot of changes, so for now we should change the command for P022.
I added an issue for it: https://github.com/letscontrolit/ESPEasy/issues/1471
iBobík
#3 Post by iBobík » 29 May 2018, 14:33
Is there some workaround what can be done remotely without OTA (my module has only 1M flash)?
I use this command in rule.
#4 Post by TD-er » 29 May 2018, 20:32
I'm afraid not.
You could do a 2-step OTA.
cowboytronic
#5 Post by cowboytronic » 03 Jun 2018, 05:44
TD-er wrote: 28 May 2018, 22:55 This is indeed a bug.
Thanks! It looks like it is being investigated and will be fixed. I'll stay on the working version for the time being, and test an update when the fix is released.
