Rule parsing issue or cannot be done?
mrwee
#1 Post by mrwee » 05 Jul 2021, 16:54
Running ESPEasy (ESP_Easy_mega_20210503_normal_ESP8266_4M1M) on an original Wemos D1 mini, I'm struggling a bit with a rule, it seems like it's not parsed correctly.
I have two devices:
The rule:
on MQTT1#Direction do
 if [MQTT1#Direction]=[Dummy1#Direction]
   publish "Pool_3wayValve/test","MQTT2"
   publish "Pool_3wayValve/test","MQTT3"
But I get the error:
65732196: IMPT : [MQTT1#Direction] : 0.00
65732285: EVENT: MQTT1#Direction=0.00
65732340: ACT : publish 'Pool_3wayValve/test','MQTT3'
65732366: ACT :  endif
65732371: Command unknown:  endif
I also tried:
 if [MQTT1#Direction]!=[Dummy1#Direction]
but that gives an "Command unknown: endif" error in last != if statement.
Re: Rule parsing issue or cannot be done?
#2 Post by Ath » 05 Jul 2021, 20:11
I tried the first code you published, and it does seem to work as intended.
Have you checked if there are unexpected (control)characters hidden in the script? I copied from the forum, and it does look right, but maybe in your rules file it isn't correct. Using Notepad++ you can use View/Show Symbol/Show All Characters to display all characters, maybe there is a line-feed instead of a cr/lf, or the files has a unicode-bom (byte order mark) as inserted by Windows Notepad when entering accented characters?
Is there other incomplete code in these rules, maybe even in one of the other rules files 1..4, like an unclosed if/endif in another event handler (on ... do/endon) or an unclosed on ... do/endon?
#3 Post by TD-er » 05 Jul 2021, 23:00
Better compare using %eventvalue1% instead of [MQTT1#Direction]
Still I don't see any obvious error
mrwee
#4 Post by mrwee » 05 Jul 2021, 23:34
Thanks both.
I'm really struggling with rules for a new device right now. It was not any illegal character, and I'm below the 2048 character limit, but it simply either complaints about my endif or commands which are unknown. Don't understand why, at all :o
Reason for using [MQTT1#Direction] is an attempt on finding the problem.
Guess I need to really take it apart, and see which part messes it up.
Just for clarification. Can I nest calling events, like:
  event,SetToggle
on SetToggle do
  event,DoThis
on DoThis do
#5 Post by TD-er » 05 Jul 2021, 23:48
Yes you can, but calling event from event etc. is a good receipt to crash due to stack overflow.
Best to call it using asyncevent.
Asyncevent will be added to a queue and dealt with in a next run to parse rules.
mrwee
#6 Post by mrwee » 06 Jul 2021, 08:36
got it. But as I understand it, asyncevent might get executed in a non-seqential order as opposed to event?
I got my rules working, no idea why. But it seems very sensitive as to when they work and when they dont. Cannot figure out what's causing it.
#7 Post by TD-er » 06 Jul 2021, 09:21
Well yes and no...
The "event" command is executed immediately.
The asyncevent is added to a queue and that queue is executed in order it was appended to the queue.
So if you only use asyncevent for events you create, you know those will be executed in the order you created them.
There is one thing to keep in mind.
Not all events generated by ESPEasy are "events", some do not need to be executed immediately and thus are also appended to this same queue as the asyncevent calls.
Whether it must be executed immediately depends on the source of the event.
For example an event for which the reply must be sent back to the source (e.g. via serial, MQTT or http call) are handled immediately.
But events for new values from a task are added to the queue.
mrwee
#8 Post by mrwee » 06 Jul 2021, 09:49
Thx for that explanation. It's a bit difficult to forsee how these conditions affects a specific rule execution when dealing with different devices, MQTT publish / import, internal variables, dummies etc.
However I have not had huge issues with rules before, but somehow this time it's acting up ;)
#9 Post by Ath » 06 Jul 2021, 10:51
It can be caused by another part of your rules, so you might want to check on your syntax for other events/rules files as well.
If possible you can share them here, more eyes that can help you identify the cause.
mrwee
#10 Post by mrwee » 06 Jul 2021, 13:31
Sure, thanks for your support. Right now it seems to work, but I'll post all rules if I end up in it again.
I also experienced the situation where all 4 rule pages, only showed the first page. I think that it's wise to wipe all rules, reboot and paste again if a similar situation occurs again.
mrwee
#11 Post by mrwee » 06 Jul 2021, 19:54
Wow. After I got the rule engine working again, I could reduce the code to a minimum.
My project was modifying a 3-Way pool valve from a pre-fabricated controller
to being managed by ESPEasy with easy toggle switch and valve status indication :).
Status can be controlled/viewed in Home Assistant :D
Love it :)
All that's missing is the automatic temperature control with different mode-settings, which I need to get my head around.
Code:
 if %eventvalue1%!=[Dummy1#Direction]
    asyncevent,SetState=%eventvalue1%
on Button#State=0 do
 let,1,1-[Dummy1#Direction]
 asyncevent,SetState=[VAR#1]
on SetState do
  timerset,2,0
  timerset,3,0
  taskvalueset,7,1,%eventvalue1%
  if %eventvalue1%=1
     publish "Pool_3wayValve/Valve_status","Moving to solar"
     mcpgpio,10,1 // RED ON
     mcpgpio,11,0 // Green OFF
     mcpgpio,13,1 // Solar heater
     publish "Pool_3wayValve/Valve_status","Moving to direct"
     mcpgpio,10,0 // Red OFF
     mcpgpio,11,1 // GREEN ON
     mcpgpio,13,0 // Direct
  mcpgpio,12,0 // Power ON
  timerset,2,17
  looptimerset_ms,3,400
on Rules#Timer=2 do
   mcpgpio,12,1 // Power OFF
   mcpgpio,13,1 // No power to direction
   timerset,3,0
   if [Dummy1#Direction]=0
      publish "Pool_3wayValve/Valve_status","Direct"
      publish "Pool_3wayValve/Valve_status","Solar"
on Rules#Timer=3 do
   if [Dummy1#Direction]=1 // Reversed
      MCPLongPulse_ms,10,0,200
      MCPLongPulse_ms,11,0,200
#12 Post by TD-er » 06 Jul 2021, 20:19
Just browsed through the code and saw this:
I assume the button is configured to be a "normal" button?
If it is configured as a toggle button, it may not work as you intended.
mrwee
#13 Post by mrwee » 06 Jul 2021, 20:39
Yes, it's a normal switch button. Had forgotten all about the toggle button :o
#14 Post by TD-er » 06 Jul 2021, 21:00
Not sure if using the toggle button is a good idea here.
The button press does seem to reverse direction and using a toggle button is only useful if you plan to use its internal state.
But this state is not updated when the direction has changed, so it then is no longer usable as "switch direction" option, but more like a direction override/confirmation when pressing it.
So what you have now is probably the most intuitive one.
mrwee
#15 Post by mrwee » 06 Jul 2021, 21:26
ok. I'll keep it as it is. Also since it's working :D
