Wrong Analog Values with ADS1115
Koenig
#1 Post by Koenig » 12 Jul 2021, 12:26
I have the following problem: Analog values that are delivered via an ADS1115 sometimes behave paradoxically. E.g. the cistern (measured by an infrared sensor) rises when it rises, although it sinks. The same problem exists with the humidity sensor. After a period of time, the values will always adjust again. The problem mainly occurs when the values change. Does anyone have any idea what could be the reason?
Re: Wrong Analog Values with ADS1115
#2 Post by TD-er » 12 Jul 2021, 12:38
What build are you running?
