ESP8266 Outputs?
ESP8266 Outputs?
Hello!
How do I configure Outputs, can not find a presetting for it? (Test_A)
Sry for stupid questions, still starting.
THX
THX
Re: ESP8266 Outputs?
You can set a GPIO using the GPIO command from a rule, or send an external command using the http://esp_ip_address/control?cmd="gpio,2,0" syntax.
Rules need to be enabled on the Tools/Advanced page before you can use that.
Outputs are switched via ioBroker over Mqtt.
There are also the Domoticz Helper and MQTT Import plugins that enable getting (numeric) data to your ESP, Domoticz Helper can directly set a GPIO pin to a state (or inverted), and MQTT Import generates events when receiving a value
(event: Import#value=<numeric-value>)
Handle such event:
Handle such event:
on Import#value do
if %eventvalue1% > 23
GPIO,2,1 // Turn fan on
if %eventvalue1% < 20
gpio,2,0 // turn fan back off (with a hysteresis built in)
OK, thx.
But I do not even have a clue where I should start and program that?
Then the best MQTT controller to use would be the Home Assistant (openHAB) MQTT controller, as that has the feature of sending the %sysname%/cmd topic with a command in the payload, assuming the MQTT Controller subscriibe field is set to %sysname%/#
(When sending from ioBroker, %sysname% should be replaced with the ESP's Client ID, as shown on the Controller page.)
More reading to do:4711Austria wrote: ↑06 Aug 2021, 16:13 OK, thx.
https://espeasy.readthedocs.io/en/lates ... Rules.html
SHT31 is working fine via Home Assist and Mqtt to ioBroker (Sonoff).
Inputs are not shown in ioBroker? (other thread)
Only Outputs I do not understand, how should I configure that Pin ? missing a Device to configure.
When using the OpenHAB MQTT controller you can also send commands to ESPEasy.
For this you need to publish a message to the topic your controller subscribes to, with "/cmd" appended to the topic.
I do not know how that works, normaly I just switch the Object in ioBroker, the Adapter does the Mqtt.
Switching over Mqtt Cmd is an option.
But is there not a Device to show the Output?
You can use a Switch to show the state of a GPIO pin, I use that to have the second Led of my Sonoff S20s visible in the UI.
Do not expect you can change that gpio pin-state using that device though, you'll need a regular 'gpio,<pin>,<state>' command for that
Users browsing this forum: Bing [Bot] and 16 guests
