I tried to change a display on my esp8266 (from 0,96" to 1,54"). After changing the web interface look different? I tried to make a firmware update, but it does not work. What can I do?
Thanks and best regards
Webinterface looks different
- Screenshot-Nov.-14-2023_20.45.43.jpg (46.65 KiB) Viewed 2965 times
Re: Webinterface looks different
Welcome, join the club.
The server which hosts the CSS and JavaScript files is now no longer serving the files.
So we're working on a fix.
See the zip file posted here: viewtopic.php?p=66902#p66902
All files in the zip can be uploaded to the ESP via the File Browser page.
All except the JavaScript file with the longest file name...
You need to rename the file "update_sensor_values_device_page.js" from that ZIP file and rename it to "upd_values_device_page.js" and upload it to the file system.
Thanks, I tried to upload all files (also the renamed file, but it is still the same problem there?
I tried it again to upload all files, without any success? What can I additionally do?
- Screenshot-Nov.-16-2023_23.02.51.jpg (47.65 KiB) Viewed 2930 times
The file "esp.css" is missing.
I thought i put it in the zip-file.
One reason it is missing, even if you tried to upload it, is that you have not enough free space on your esp.
You find that info under /tools/info
Thanks, this I didn´t saw. Here are the info about the memory. It seems that there is enough, or? If I try to upload the esp.css it begin to upload and then the screen is empty. It look different to the other files. There comes after uploading the information to reboot.
What can I do?
What can I do?
- Screenshot-Nov.-20-2023_20.11.29.jpg (40.4 KiB) Viewed 2873 times
You could try another browser, it seems Chrome is really optimized (read: lazy) recently at uploading files, causing all kinds of issues.
I see similar behavior when uploading an OTA .bin, and have configured Chrome to not slow/sleep unused tabs. That seems to help a bit.
Users browsing this forum: Bing [Bot] and 3 guests
