NodeMCU V3 AI-Thinker version
dgcracker
#1 Post by dgcracker » 06 Mar 2018, 06:25
I have problem with NodeMCU V3 with AI-Thinker 8266 module. I flashed it with different versions (with different loading speed 9600, 115200) of ESP Easy firmware but the device does not show up as an access point ESP_EASY_0 or ESP_0. After boot only blue led blinks one time ant that’s all. When I connect to module with COM connection via Putty I see only randomly generated characters. During loading firmware there is no problem – it looks like everything goes OK, blue led flash during programming etc. It’s not my first NodeMCU board and previously I had no problems with flashing it. Photos of my board in attachments. Any suggestions how to load firmware into this module?
dgcracker
Re: NodeMCU V3 AI-Thinker version
#2 Post by dgcracker » 07 Mar 2018, 07:41
After connecting this module via COM and Putty and nothing more :(
NDR008
#3 Post by NDR008 » 07 Mar 2018, 17:01
dgcracker wrote: 06 Mar 2018, 06:25 When I connect to module with COM connection via Putty I see only randomly generated characters
Try changing the baudrate and resetting the ESP.
Hopefully it will become logical characters.
dgcracker
#4 Post by dgcracker » 13 Mar 2018, 09:19
I tried different baudrate, different firmware versions and size and still nothing. It’s seams like module is corrupt :(
ssathya
#5 Post by ssathya » 16 Mar 2018, 23:23
Did you find a resolution? Tried on a couple of boards (1 NodeMCU and 2 Wemos) and same issue. The led blinks once or twice and nothing else happens. Tried to flash more than 2 or 3 times on each of the devices.
#6 Post by grovkillen » 16 Mar 2018, 23:37
You could try my Flasher (wrapper for the official command line tool), which will let you program the unit right after flash and connect to the wifi without the need for a AP.
budman1758
#7 Post by budman1758 » 17 Mar 2018, 03:12
Hope there isn't a PUYA chip under that metal cover..... :shock:
ssathya
#8 Post by ssathya » 18 Mar 2018, 21:09
@grovkillen will give it a try tomorrow. Went through your Github page and believe it might solve my issue.
@budman1758 not sure about what chip is under the shield but my NodeMCU and Wemos boards were obtained over the past 3 to 4 months and when I try other WiFi-enabled programs they work okay.
ssathya
#9 Post by ssathya » 19 Mar 2018, 20:20
@grovkillen you are the man!
Yes, it worked and actually flashing ESP8266 using your tool makes ESP Easy => ESP Easier! Don't have to disconnect my computer from network fiddle with access point etc.
#10 Post by grovkillen » 19 Mar 2018, 20:36
ssathya wrote: 19 Mar 2018, 20:20 @grovkillen you are the man!
You warm a old mans heart :D Thank you for the feedback!
