I only see the mac address but no ip.
jpascher
#1 Post by jpascher » 07 Apr 2018, 12:12
Did set perhaps a wrong static ip Adresse but now i cant get at the AP.
Refashing als seams not to help. Dos the wemos keep the settings after flashing?
I would need to reset all as i can if i load a more rudimentäre image via Arduino. with the line wifiManager.resetSettings();
Bin file in use:
ESP_Easy_mega-20180405_dev_ESP8266_4096.bin
I am relay new to the project, so please be Patient with me.
Console log:
WIFI : AP Mode disabled
WIFI : AP Mode ssid will be ESP_Easy-0 with address 192.168.4.1
IP : Static IP :3355486400
WIFI : Connected! AP: W900JP (E8:DF:70:6C:81:83) Ch: 13
WD : Uptime 0 ConnectFailures 0 FreeMem 14352
WD : Uptime 1 ConnectFailures 0 FreeMem 14352
Re: I only see the mac address but no ip.
#2 Post by grovkillen » 07 Apr 2018, 12:14
Please use 20180319 or something close to that date since we're fixing stuff with the WiFi and users might experiencing trouble configuring clean, new, units.
jpascher
#3 Post by jpascher » 07 Apr 2018, 12:22
Thank for the answer i will tray a older version.
jpascher
#4 Post by jpascher » 07 Apr 2018, 14:29
Where can i find an older bin file?
#5 Post by grovkillen » 07 Apr 2018, 14:30
On GitHub under releases.
jpascher
#6 Post by jpascher » 07 Apr 2018, 15:35
jpascher
#7 Post by jpascher » 07 Apr 2018, 15:53
Thanks, looks like all setting i made before are still there.
For me it looks like the ip address war red with the newer image the wrong way round, i saved 192.168.0.200 but 200.0.168.192 in dezimal (3355486400) was red.
Bootlog now:
INIT : Booting version: v2.0-20180319
INIT : Warm boot #3
FS : Mounting...
FS : Mount successful, used 75802 bytes of 957314
INIT : Free RAM:19432
INIT : I2C
INIT : SPI not enabled
WIFI : AP Mode ssid will be ESP_Easy_0 with address 192.168.4.1
IP : Static IP :192.168.0.200
WIFI : Connecting W900JP attempt #0
WD : Uptime 0 ConnectFailures 0 FreeMem 16880
WIFI : WiFi connect attempt took: 1008 ms
WIFI : Connected! IP: 192.168.0.200 (ESP_Easy_0) AP: W900JP AP BSSID: E8:DF:70:6C:81:83
Users browsing this forum: Anthropic Claude Bot [bot], Bing [Bot] and 20 guests
