Did set perhaps a wrong static ip Adresse but now i cant get at the AP.
Refashing als seams not to help. Dos the wemos keep the settings after flashing?
I would need to reset all as i can if i load a more rudimentäre image via Arduino. with the line wifiManager.resetSettings();
Bin file in use:
ESP_Easy_mega-20180405_dev_ESP8266_4096.bin
I am relay new to the project, so please be Patient with me.
Console log:
WIFI : AP Mode disabled
WIFI : AP Mode ssid will be ESP_Easy-0 with address 192.168.4.1
IP : Static IP :3355486400
WIFI : Connected! AP: W900JP (E8:DF:70:6C:81:83) Ch: 13
WD : Uptime 0 ConnectFailures 0 FreeMem 14352
WD : Uptime 1 ConnectFailures 0 FreeMem 14352
I only see the mac address but no ip.
Re: I only see the mac address but no ip.
Please use 20180319 or something close to that date since we're fixing stuff with the WiFi and users might experiencing trouble configuring clean, new, units.
Thank for the answer i will tray a older version.
Where can i find an older bin file?
On GitHub under releases.
Thanks, looks like all setting i made before are still there.
For me it looks like the ip address war red with the newer image the wrong way round, i saved 192.168.0.200 but 200.0.168.192 in dezimal (3355486400) was red.
Bootlog now:
INIT : Booting version: v2.0-20180319
INIT : Warm boot #3
FS : Mounting...
FS : Mount successful, used 75802 bytes of 957314
INIT : Free RAM:19432
INIT : I2C
INIT : SPI not enabled
WIFI : AP Mode ssid will be ESP_Easy_0 with address 192.168.4.1
IP : Static IP :192.168.0.200
WIFI : Connecting W900JP attempt #0
WD : Uptime 0 ConnectFailures 0 FreeMem 16880
WIFI : WiFi connect attempt took: 1008 ms
WIFI : Connected! IP: 192.168.0.200 (ESP_Easy_0) AP: W900JP AP BSSID: E8:DF:70:6C:81:83
Bootlog now:
INIT : Warm boot #3
FS : Mounting...
INIT : I2C
Users browsing this forum: Ahrefs [Bot], Anthropic Claude Bot [bot] and 17 guests
