mqtt import value on display
hello,
I need to take a temperature value from a mqtt broker
I used to test test.mosquitto.org.
With mqtt import I managed to import the value.
How can I now send the value to the display connected to espeasy?
thanks
thanks
- ESP_device.png (51.25 KiB) Viewed 7278 times
- esp_controller.png (48.01 KiB) Viewed 7278 times
Re: mqtt import value on display
And you have studied the wiki?
Given that your display is an OLED:
https://www.letscontrolit.com/wiki/inde ... LEDDisplay
Given that your display is (simple) LCD:
https://www.letscontrolit.com/wiki/index.php/LCDDisplay
Use the commands together with rules:
https://www.letscontrolit.com/wiki/inde ... rial_Rules
can you help me with the rules?
First off, what display of are you using?
The 2004
On extmqtt#Value1 do
LCD,1,1,[extmqtt#Value1] //LCD,<row>,<col>,<text>
EndOn
