I want a switch to be pushed remotely...
LexHoub
#1 Post by LexHoub » 15 Oct 2018, 09:52
I use ESP_EASY in combination with Homeseer.
As controller I call HomeSeer_REST_API.aspx with IDX as device number.
This works perfect when I am near the actual light-switches that are build into the wall with an ESP behind it.
But is there a way to simulate that a button is pushed (so force an input to get high/low)?
Why do I need this?
My switches are at several place in my home and my office is at the first floor. So every time I am testing I must run through the house.
Or even worse: When I am not at home and want to change and test something.
I would be so much easier to simulate the change of an input!
Here is my devicelist
Alex
Wiki
Re: I want a switch to be pushed remotely...
#2 Post by Wiki » 15 Oct 2018, 11:20
have a look here: https://www.letscontrolit.com/wiki/inde ... #HTTP_call
May be this will help you.
pi@raspberrypi:~ $ man woman
No manual entry for woman
pi@raspberrypi:~ $
LexHoub
#3 Post by LexHoub » 15 Oct 2018, 12:45
Going to check it now!
LexHoub
#4 Post by LexHoub » 15 Oct 2018, 13:11
Seems to work!!
I use <<ESP IP>>/control?cmd=event,L2on
My ruleset 1:
 On L2on do
 gpio,0,1 //Set input 0 High
  timerSet,1,1 //timer 1 set for 1 sec
On L2off do
  timerSet,1,0 //timer 1 set to halt,
  gpio,0,0 //Set input 0 low (normal state)
On Rules#Timer=1 do
endOn
The log output looks like this:
481240: EVENT: L2on
481250: ACT : gpio,0,1
481253: SW : GPIO 0 Set to 1
481257: ACT : timerSet,1,1
481284: Command: timerset
481337: SW : Switch state 1 Output value 1
481339: EVENT: L2#S=1.00
482048: WD : Uptime 8 ConnectFailures 0 FreeMem 14592
482736: EVENT: Rules#Timer=1
482752: ACT : gpio,0,0
482754: SW : GPIO 0 Set to 0
So the input gets HIGH and with help from the controller my homeseer device is set!
THANKS!!!!!!!! :D :D :D
Alex
dynamicdave
#5 Post by dynamicdave » 16 Oct 2018, 12:09
Thanks for sharing this - brilliant use of 'Rules' and 'Events'.
I've got a set of IR detectors around the outside of my house that drive WeMos D1 Minis that pass info via MQTT to Node-RED.
I've now implemented your 'hints/suggestion' and can now test my system remotely - yipppeeee.
PS: I'm using an 'mqtt' node to send the event rather than an 'http' node.
Thanks again.
Regards from David.
Users browsing this forum: No registered users and 26 guests
