Hello, since I'm new int the board and in the automation do I want to say Hello to all of you.
I have a problem with flashing the ESPEasy to the Sonoff basic - the new board (The one with the four pins 3,3V, TX, RX, GND).
I've used the ESPEasy_mega-20191208 and loaded the firmware ESP_Easy_mega-20191208_normal_ESP8285_1M.bin to the device.
All went ok, but I cant use any of the GPIO's. Some of the ones that should be working as the button relay controller, also the led controller as well I wanted to use the DHT22 to get the temperature. None of them works as it's described in tutorials in internet.
Does anyone knows which firmware should I put to the Sonoff and which GPIO are responsable for wchich elements?
Best regards
Sonoff new board flashing
Re: Sonoff new board flashing
That version should work. What tutorials do you use?
can't find it now, but do you know or have some info where to find the GPIO description - which controls what?
ok, found one:
https://rutg3r.com/sonoff-firmware-tuto ... -esp-easy/
or this:
https://www.domoticz.com/forum/viewtopi ... 0&start=40
ok, found one:
or this:
ok, great, but if I connect dht22 to the 3,3V, GND and Rx, how to read the data from it?
You need to turn off the serial (set in the advanced section) and configure it like any other device (set it up on the device page,).
