Sonoff new board flashing
krzyzaq
#1 Post by krzyzaq » 12 Jan 2020, 18:40
Hello, since I'm new int the board and in the automation do I want to say Hello to all of you.
I have a problem with flashing the ESPEasy to the Sonoff basic - the new board (The one with the four pins 3,3V, TX, RX, GND).
I've used the ESPEasy_mega-20191208 and loaded the firmware ESP_Easy_mega-20191208_normal_ESP8285_1M.bin to the device.
All went ok, but I cant use any of the GPIO's. Some of the ones that should be working as the button relay controller, also the led controller as well I wanted to use the DHT22 to get the temperature. None of them works as it's described in tutorials in internet.
Does anyone knows which firmware should I put to the Sonoff and which GPIO are responsable for wchich elements?
Best regards
Re: Sonoff new board flashing
#2 Post by grovkillen » 12 Jan 2020, 19:14
That version should work. What tutorials do you use?
krzyzaq
#3 Post by krzyzaq » 12 Jan 2020, 20:18
can't find it now, but do you know or have some info where to find the GPIO description - which controls what?
ok, found one:
https://rutg3r.com/sonoff-firmware-tuto ... -esp-easy/
or this:
https://www.domoticz.com/forum/viewtopi ... 0&start=40
#4 Post by grovkillen » 12 Jan 2020, 22:10
krzyzaq
#5 Post by krzyzaq » 12 Jan 2020, 22:28
ok, great, but if I connect dht22 to the 3,3V, GND and Rx, how to read the data from it?
#6 Post by grovkillen » 12 Jan 2020, 23:30
You need to turn off the serial (set in the advanced section) and configure it like any other device (set it up on the device page,).
