Shelly 1 +Temperature Shield
Has anyone managed to get ESPEasy to read the Temperature from the shield?
I just can't seem to get it working with ESPEasy. With the original Shelly firmware it works.
I added the picture of the official shield.
Thanks in advance!!!
Sieth
Sieth
- shelly-shelly-temperature-add-on-for-shelly-1-1pm.jpg (100.83 KiB) Viewed 15065 times
Re: Shelly 1 +Temperature Shield
I'm not a Shelly user, but from reviewing the device pin-out it appears the DS18B20 would be configured to use GPIO-0.
If that GPIO pin does not work for you then I suggest you post a clear photo of your wiring and a screenshot that shows your Environment-DS18b20 plugin settings. The images will help the Shelly users see what might need to change in your setup.
Thomas,
I've included all the printscreens and photo's of my setup.
I Used GPIO-0 but no reading.
Greetings,
Sieth
Greetings,
Sieth
- esp2.jpg (160.14 KiB) Viewed 14980 times
- esp1.jpg (79.07 KiB) Viewed 14980 times
- 72612777-03029080-392e-11ea-9efd-9fc00d9621cf.jpg (700.47 KiB) Viewed 14980 times
- 72612776-03029080-392e-11ea-9b1e-361591be1a65.jpg (785.87 KiB) Viewed 14980 times
The setup seen in the screenshot looks reasonable. Are you sure the shield and DS18B20 sensor are still good? I suggest re-testing them on the original Shelly firmware to confirm operation.
I didn't find any useful info on using the Shelly 1 shield. So maybe you are wandering in uncharted territory. Hopefully someone that has walked in your shoes will drop by and lend a hand.
BTW, don't operate without the plastic covers. They protect you from the un-isolated side of AC mains.
Indeed it works with the original Shelly firmware. So I know it's a firmware thing.
I think i'll have you wait until someone finds out how it can be fixed.
Thank you so far!
Thank you so far!
And you have tried all the GPIOs? Sounds simple enough since it's only one pin you have to get right.
I found some experimental code for the Shelly 1 shield on a Tasmota github:I think i'll have you wait until someone finds out how it can be fixed.
https://github.com/arendst/Tasmota/comm ... e14a38eeb6
Unfortunately it shows that the DS18B20 temperature sensor will require two I/O pins: Output=GPIO-0, Input=GPIO-3. This isn't supported by ESPEasy's DS18B20 plugin.
It seems that the two GPIO pins are due to the isolation circuitry in the Shelly Shield. The shield uses a ISO7221A Dual Digital Isolator IC that supports two unidirectional signals. So the expected bi-directional access to the "One-Wire" DS18B20 has been split into separate input and output paths.
Long story short, ESPEasy currently will not support this particular Shelly application.
Shelly 1 requested ESP_Easy_mega-20200204_normal_ESP8266_1M.bin. Disconnected the port and used RX (gpio3), TX (gpio1) to connect the temperature sensor.
The Shelly1 also has 2M flash, so if possible I would go for that build as it will make upgrading the firmware a lot easier.
