Shelly 1 +Temperature Shield
sieth
#1 Post by sieth » 30 Jan 2020, 16:19
Has anyone managed to get ESPEasy to read the Temperature from the shield?
I just can't seem to get it working with ESPEasy. With the original Shelly firmware it works.
I added the picture of the official shield.
Thanks in advance!!!
Sieth
Re: Shelly 1 +Temperature Shield
#2 Post by ThomasB » 30 Jan 2020, 20:48
I'm not a Shelly user, but from reviewing the device pin-out it appears the DS18B20 would be configured to use GPIO-0.
If that GPIO pin does not work for you then I suggest you post a clear photo of your wiring and a screenshot that shows your Environment-DS18b20 plugin settings. The images will help the Shelly users see what might need to change in your setup.
sieth
#3 Post by sieth » 01 Feb 2020, 19:19
Thomas,
I've included all the printscreens and photo's of my setup.
I Used GPIO-0 but no reading.
Greetings,
Sieth
#4 Post by ThomasB » 01 Feb 2020, 20:17
The setup seen in the screenshot looks reasonable. Are you sure the shield and DS18B20 sensor are still good? I suggest re-testing them on the original Shelly firmware to confirm operation.
I didn't find any useful info on using the Shelly 1 shield. So maybe you are wandering in uncharted territory. Hopefully someone that has walked in your shoes will drop by and lend a hand.
BTW, don't operate without the plastic covers. They protect you from the un-isolated side of AC mains.
sieth
#5 Post by sieth » 02 Feb 2020, 19:47
Indeed it works with the original Shelly firmware. So I know it's a firmware thing.
I think i'll have you wait until someone finds out how it can be fixed.
Thank you so far! ;)
#6 Post by grovkillen » 02 Feb 2020, 20:51
And you have tried all the GPIOs? Sounds simple enough since it's only one pin you have to get right.
#7 Post by ThomasB » 02 Feb 2020, 20:54
I found some experimental code for the Shelly 1 shield on a Tasmota github:
https://github.com/arendst/Tasmota/comm ... e14a38eeb6
Unfortunately it shows that the DS18B20 temperature sensor will require two I/O pins: Output=GPIO-0, Input=GPIO-3. This isn't supported by ESPEasy's DS18B20 plugin.
It seems that the two GPIO pins are due to the isolation circuitry in the Shelly Shield. The shield uses a ISO7221A Dual Digital Isolator IC that supports two unidirectional signals. So the expected bi-directional access to the "One-Wire" DS18B20 has been split into separate input and output paths.
Long story short, ESPEasy currently will not support this particular Shelly application.
Kalm6
#8 Post by Kalm6 » 15 Feb 2020, 21:22
Shelly 1 requested ESP_Easy_mega-20200204_normal_ESP8266_1M.bin. Disconnected the port and used RX (gpio3), TX (gpio1) to connect the temperature sensor.
#9 Post by TD-er » 16 Feb 2020, 11:31
The Shelly1 also has 2M flash, so if possible I would go for that build as it will make upgrading the firmware a lot easier.
