ESP Easy - hivemq
Beowolf
ESP Easy - hivemq
#1 Post by Beowolf » 28 Aug 2024, 10:38
Hello everyone,
how do I get the connection to this mqtt broker provider?
https://www.hivemq.com/
This is where an "IP" cluster URL is generated.
686134589c624329828efc3cb72095d8.s1.eu.hivemq.cloud
How or where do I enter this in ESPEASY?
Manfred
Re: ESP Easy - hivemq
#2 Post by TD-er » 28 Aug 2024, 10:46
You normally should change to use DNS, but I'm not sure if such long URLs can be stored in the settings.
So I think you may have found an issue which cannot be solved without changing settings structure.
Does this broker platform also support some other ways like a shorter URL but then use this hex value as user credentials?
Beowolf
#3 Post by Beowolf » 28 Aug 2024, 10:58
Thats all
#4 Post by TD-er » 28 Aug 2024, 11:04
I just tried it here on a node and I can store the hostname just fine.
Apparently there is enough space (have not looked at the source code yet)
Screenshot 2024-08-28 110258.png (33.88 KiB) Viewed 4238 times
Screenshot 2024-08-28 110238.png (46.41 KiB) Viewed 4238 times
#5 Post by TD-er » 28 Aug 2024, 11:06
Ah I notice you need TLS, which is not included right now in ESPEasy.
There is a pending PR to add TLS support for MQTT, but this does not compile right now for "LittleFS" builds.
Can you see if there is some build here you can test: https://github.com/letscontrolit/ESPEas ... 0516654841
Just to make sure it is a TLS problem or not....
Beowolf
#6 Post by Beowolf » 28 Aug 2024, 15:36
TLS is necessary
#7 Post by TD-er » 28 Aug 2024, 15:36
Have you tried with one of the test builds I linked?
Beowolf
#8 Post by Beowolf » 28 Aug 2024, 15:45
Not yet - No time at the moment
Beowolf
#9 Post by Beowolf » 30 Aug 2024, 18:02
I can't find a BIN for a Wemos D1 mini.
A link would be helpful.
Thank you
#10 Post by TD-er » 30 Aug 2024, 20:11
And there won't be any as TLS is way to much demanding for ESP8266.
We simply do not have the free RAM for it as it requires 20 - 23 kB of free memory and it also extends the binary size way too much.
So no TLS for ESP8266 in ESPEasy.
Beowolf
#11 Post by Beowolf » 30 Aug 2024, 20:45
OK. Too bad, then I'll have to stick with Tasmota for TLS. It works with a Wemos D1 mini without any problems.
Thanks anyway
