toffel969
#11
Post
by toffel969 » 23 Oct 2017, 19:59
vader wrote: ↑23 Oct 2017, 19:44
I've tested it and does not work for me. I mean, you can not transmit values to an event. The parser seems to ignore more than 1 value after "event". It is only interested in the event name....
The messed rules seem to be an issue of core 2.4.0....
You can send values, check the wiki
https://www.letscontrolit.com/wiki/inde ... _Variables
vader
#12
Post
by vader » 23 Oct 2017, 20:10
Ok, now I got it. The "=" after event name was wrong (I had ",")...
danmero
#13
Post
by danmero » 23 Oct 2017, 23:16
on testevent do
TaskValueSet 5,4,%eventvalue%
http://x.x.x.x/control?cmd=event,testevent=3
This works on 2.0.0.x
rayE
#14
Post
by rayE » 24 Oct 2017, 02:53
Thanks guy's, this works a treat
#15
Post
by grovkillen » 24 Oct 2017, 07:54
toffel969 wrote: ↑23 Oct 2017, 19:59
I have now moved this section to its correct section
https://www.letscontrolit.com/wiki/inde ... alue.25.29
I hope more people will use this awesome technique (I sure hadn't seen it before you pointed it out).
danmero
#16
Post
by danmero » 20 Nov 2017, 15:20
I use this rule set to pass GPIO # as event argument.
on sniff#a do
event event1=%eventvalue%
on event1 do
pcfpulse %eventvalue%,0,200
Regards,
#17
Post
by grovkillen » 20 Nov 2017, 16:32
danmero wrote: ↑20 Nov 2017, 15:20
on sniff#a do
on event1 do
Regards,
Clever, will try to add this to the wiki as well.
Users browsing this forum: Anthropic Claude Bot [bot], Bing [Bot] and 49 guests
