RULES - own section - syntax explain - SENDtoUDP
tozett
#1 Post by tozett » 24 Apr 2016, 11:33
i am playing with rules,
seems an important new function for homeautomation control, directly on the device.
Maybee the admins should consider making an own section for rules
as a growing source of knowledge?
1) ----------------------------------------
would be helpful to have clearer explanation in wiki for the syntax of <event> creation.
i attach an image, if i got this right.
also a list of possible actions could help to prevent searching the source..
2) --------------------------------
AND MY personal BIG WISH:
maybe the dev could expand/clone the SendTO command to a
SendToUDP (port/ip)
command ? i assume that not so much work,
(as it is already udp to other deviced)
but would widen the possibilites to send sensor-values directly from the device around the net.
i would use this to send the RFID-Tag values to my homeserver for door-opening.
Would really appreciate this function.. ;-)
tozett
Re: RULES - own section - syntax explain - SENDtoUDP
#2 Post by tozett » 24 Apr 2016, 14:07
by inccident if found out, that one can check the right syntax in the log,
where EVENTS are logged like:
EVENT: wifi-rssi#wifi-rssi=-46.00
EVENT: dht-11#Humidity=19.00
maybe worth to mention in the wiki?
Martinus
#3 Post by Martinus » 25 Apr 2016, 15:20
tozett wrote: AND MY personal BIG WISH:
SendToUDP (port/ip)
Have a look at R104 release notes...
tozett
#4 Post by tozett » 25 Apr 2016, 16:39
someone mentioned r104 around lunch,
i had a quick look, but it was not there..
i will check now..
thanks a lot, that was really quick...
Emir144
#5 Post by Emir144 » 01 Jul 2016, 08:31
Hi there,
I am using a building automation system called loxone which is very flexible in terms of customization and integration with other systems and protocols. Fortunately it can handle udp very well.
I would appreciate having udp integrated in espeasy in order to send sensor values or receive commands via udp. I am definitely no coding expert, but what i found so far in the code of r104 only enables espeasy to send text only via udp.
Please developers: could you please integrate more sophisticated udp functionality in espeasy!
Many thanks
Emir
tozett
#6 Post by tozett » 01 Jul 2016, 10:07
hi,
i had the same settting with my gira homeserver (not loxone),
i can suggest building something in-between, like node-ned and communication at first everthing over mqtt, than from node-red to upd (or anything else). this is more powerful, but also simple to employ. there is information here in the forum.
just a suggestion... as i am also no developer...
Emir144
#7 Post by Emir144 » 04 Jul 2016, 09:42
Thanks for your hint.
As i intend to keep my system as simple as possible, i try to keep number of systems and protocols low. Also someone else should be able to manage and service the system. Therefore i definitely do prefer the pure udp communication...
I would really appreciate getting udp supported formsensor values...
Emir
tozett
#8 Post by tozett » 05 Jul 2016, 21:43
i think, the devs will not build everything what is on the whislist...
but how knows... i had a lot of points sticked on that list.
maybe this could help you in the meantime...?
https://github.com/jpmens/mqttwarn
