seems an important new function for homeautomation control, directly on the device.
Maybee the admins should consider making an own section for rules
as a growing source of knowledge?
1) ----------------------------------------
would be helpful to have clearer explanation in wiki for the syntax of <event> creation.
i attach an image, if i got this right.
also a list of possible actions could help to prevent searching the source..
2) --------------------------------
AND MY personal BIG WISH:
maybe the dev could expand/clone the SendTO command to a
SendToUDP (port/ip)
command ? i assume that not so much work,
(as it is already udp to other deviced)
but would widen the possibilites to send sensor-values directly from the device around the net.
i would use this to send the RFID-Tag values to my homeserver for door-opening.
Would really appreciate this function..
